81 kz 1000 carb issues (I think?)
- whitbyrudie
23 Jul 2013 14:35 #597907
by whitbyrudie
81 KZ1000 CSR
Vancouver Canada
81 kz 1000 carb issues (I think?) was created by whitbyrudie
Okay so this has been a project bike from start to finish, wasn't running when I got it and the following is a list of the things I've had to do to get it running and to get it running better.
rebuilt the carbs
replaced throttle cable
replaced speedo
replaced all front end gaskets (this was a nightmare, and as a side note, it did run fine before this, just had a mild oil leak, hence the change, but as a testament to these bikes, when we opened up the cam head, we found one of the cams was actually in backwards... wtf? But the bike still ran no problem lol)
replaced the chain
Now here is the problem I'm having and I'm assuming it's carb related. My gas consumption really freaking sucks, I've got a 17 litre (4.5) gallon HD tank on there currently, and I'm getting about 150km until it hits reserve (at about 15 litres) which is fairly redonkulas
Some other side symptoms. Getting a lot of back firing, happens when ever I let off the throttle, but always goes away if I engage the clutch.
Start is kind of weird, I usually have to engage the choke, start it, rev it, pop the clutch back in and dial up the idle adjustment so the engine doesn't die out. Then about 10-20 minutes into the ride, I need to dial the idle adjustment back so it's back to 1k otherwise it gradually jumps to 2k 2.5 and wants to idle there
my thought was adjusting the mixture to make it more lean to help the consumption, so I had the pilot screws backed out to only 1.5 turns, didn't seem to make a huge difference
any thoughts? Suggestions? I would really appreciate any comments. I've looked up the stats on the bike, granted it's a 31 year old bike but I should be getting upwards of 200km/tank on the stock (12 litre) tank, so I know something is amiss
Cheers and thanks for the help in advance!
rebuilt the carbs
replaced speedo
replaced the chain
81 KZ1000 CSR
Vancouver Canada
- koolaid_kid
- Thank you received: 99
25 Jul 2013 19:32 - 26 Jul 2013 00:13 #598263
by koolaid_kid
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Replied by koolaid_kid on topic 81 kz 1000 carb issues (I think?)
If you have the Mikuni CV carbs, you can't just spray them out with carb cleaner. They have very tiny passages that won't be reached. You have tear them completely down, soak them in carb dip for 24 hours or use an ultrasonic cleaner. Then replace all the o-rings as well. Otherwise, you will achieve the results you are reporting.
1983 GPz 750
Last edit: 26 Jul 2013 00:13 by koolaid_kid.
- Thank you received: 2098
25 Jul 2013 23:13 #598297
by Patton
Replied by Patton on topic 81 kz 1000 carb issues (I think?)
To be on the safe side, would examine and sniff-test the oil to determine possible gasoline intrusion into the crankcase.
- whitbyrudie
28 Jul 2013 23:11 - 28 Jul 2013 23:11 #598810
by whitbyrudie
81 KZ1000 CSR
Vancouver Canada
Replied by whitbyrudie on topic 81 kz 1000 carb issues (I think?)
Yup, They're Mikuni's and they were in fact dipped, not sprayed down, then visually examined each one to ensure the passage was clear and I could see through them.
Any other thoughts?
Negative on gasoline in the crank case, checked that one a few times already
Any other thoughts?
81 KZ1000 CSR
Vancouver Canada
Last edit: 28 Jul 2013 23:11 by whitbyrudie.
- Haybus
- Big Al
- Thank you received: 42
29 Jul 2013 02:26 - 29 Jul 2013 02:28 #598834
by Haybus
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
Replied by Haybus on topic 81 kz 1000 carb issues (I think?)
Generally high idle after warm means a lean idle circuit. When you blip the throttle and it takes a bit to come back down, it's probably lean. There's some good tuning instructions in the filebase that will help you out with adjustments. Backfiring is also a result of a lean condition on deceleration. Now, backfiring usually means look out people, race bike coming through :woohoo:
Do know if the carbs are CV or mechanical slide? You can't see through the passageways that will be causing problems.
Alan
Alan
2005 FJR
2009 Hayabusa
Last edit: 29 Jul 2013 02:28 by Haybus.
- Motor Head
- Thank you received: 391
29 Jul 2013 10:05 #598867
by Motor Head
Replied by Motor Head on topic 81 kz 1000 carb issues (I think?)
" but as a testament to these bikes, when we opened up the cam head, we found one of the cams was actually in backwards... wtf? But the bike still ran no problem lol)
replaced the chain"
Care to elaborate a bit on this? Backwards? Replaced "Chain", what the cam chain?
What manual are you using?
replaced the chain"
