Whats the float height of my 82 Kawa 1100 D2 Carbs
- swaluda
21 Jul 2013 20:55 - 21 Jul 2013 21:08 #597610
by swaluda
Whats the float height of my 82 Kawa 1100 D2 Carbs was created by swaluda
My manual says 18.6 but that's a 1100 A model, I don't have a manual for the D2. Maybe they are the same, I don't know. Please Help, I need to finish this thing up, Thanks,,,, Stan 82 Kawa 1100 D2 Shaft Drive Spectre BS 34 Carbs
Last edit: 21 Jul 2013 21:08 by swaluda. Reason: adding info
- peter1958
- Banned
- Thank you received: 198
21 Jul 2013 21:16 #597615
by peter1958
Replied by peter1958 on topic Whats the float height of my 82 Kawa 1100 D2 Carbs
its the same 18.6
The following user(s) said Thank You: swaluda
- Motor Head
- Thank you received: 391
21 Jul 2013 22:38 #597628
by Motor Head
Replied by Motor Head on topic Whats the float height of my 82 Kawa 1100 D2 Carbs
Be sure to check the Wet Fuel level. Use the Clear Tube Test. Patton has a tutorial on it. It is in the factory service manual. Should be about 3mm below the bowl gasket surface.
If you don't have the Factory Manual, go here: www.kawiworld.com/index.php?option=com_c...icle&id=77&Itemid=99
