1100 leaks fuel out of the far left carb
- Sinicle
19 Jul 2013 16:11 - 19 Jul 2013 16:13 #597325
by Sinicle
1981 KZ1100 a1 shaft
1100 leaks fuel out of the far left carb was created by Sinicle
Far left carb leaks fuel out the aircleaner when parked. Is this result of a stuck float or something? Any help is greatly appreciated.
Last edit: 19 Jul 2013 16:13 by Sinicle.
- mtkawboy
- Thank you received: 16
19 Jul 2013 16:38 - 19 Jul 2013 16:40 #597327
by mtkawboy
Replied by mtkawboy on topic 1100 leaks fuel out of the far left carb
That or the float level is too high. Check your oil level too, its probably going into the crankcase too. Not good to keep riding it that way
Last edit: 19 Jul 2013 16:40 by mtkawboy. Reason: more info
- Thank you received: 2098
19 Jul 2013 17:04 - 19 Jul 2013 17:12 #597332
by Patton
Replied by Patton on topic 1100 leaks fuel out of the far left carb
Probably results from a mal-functioning float valve (whereby fuel keeps rising), accompanied by an obstructed overflow circuit (fuel rises all the way up into the carb bore and flows rearward toward the air box and forward toward the engine).
The carbs at hand may not have an overflow circuit, in which event, there would be no such protection against fuel rising on up into the carb bore.
Last edit: 19 Jul 2013 17:12 by Patton.
- Thank you received: 2829
19 Jul 2013 17:51 #597339
by 650ed
Replied by 650ed on topic 1100 leaks fuel out of the far left carb
Be sure to give your oil a "sniff test" to see if it is contaminated with fuel. If gas is running out of the back of the carb it is very possible it ran out of the front of the carb into the cylinder. From there it would seep down past the rings into the crankcase. Ed
- Sinicle
19 Jul 2013 18:47 #597349
by Sinicle
Replied by Sinicle on topic 1100 leaks fuel out of the far left carb
Thanks for your feed back guys, Im headed to my buddies house to check it out
- Sinicle
27 Jul 2013 14:34 #598563
by Sinicle
Got it fixed. Turned out to be a bad O-ring on the float valve. Thanks again guys for your help
