1976 kawasaki kz750 carb
- schand_08
17 Jul 2013 00:00 #596872
by schand_08
1976 kawasaki kz750 carb was created by schand_08
i have taken my carbs apart for thorough cleaning and had vacuum leak on the rod with the butterflies does anyone know where or what size of screw holds the butterfly on?
- steell
17 Jul 2013 13:40 #596936
by steell
Replied by steell on topic 1976 kawasaki kz750 carb
Two screws on each butterfly, little tiny things that fit through hole in the butterfly and screw into the shaft.
If your throttle shaft bores are worn, a good machinist can bore out the throttle shaft bore and make bushing to press back in. Common fix on Kohler motors.
Or you can hunt around for a good set of used carbs.
