bs34 and bs36 Air Needle Jets
- swaluda
16 Jul 2013 19:34 #596822
by swaluda
bs34 and bs36 Air Needle Jets was created by swaluda
I broke down a bs36 set today and found the air needle jet had (in order) the jet, the spring, a small brass washer and a smaller black washer. Wrong carbs for my bike and filthy at that, so gonna cleam them up and sell them. OK, my BS34 Carbs off my 82 kawa 1100 d2 Spectre only had the air jet and a spring, no washers, Does that sound right. I drilled out the plugs which were aluminum and appeared to be factory sealed, However, maybe when I bought the bike someone had been in there before me.. Need help on this one because I have a rebuid kit coming in a day or two.... Thanks, Stan
- Motor Head
- Thank you received: 391
16 Jul 2013 23:20 #596854
by Motor Head
Replied by Motor Head on topic bs34 and bs36 Air Needle Jets
On your BS34 carbs, the Mixture screw will have an 0-ring on it, near the screw head, between the threads and the screw head. Hopefully they are in the rebuild kit, if K&L kit, then i believe they are.
The following user(s) said Thank You: swaluda
- KZ-Izzo
- Thank you received: 2
22 Jul 2013 16:44 #597740
by KZ-Izzo
Live Fast
1980 KZ1000 b4 ltd
Replied by KZ-Izzo on topic bs34 and bs36 Air Needle Jets
how much for the bs36's as is and do you have pics of both?
Live Fast
1980 KZ1000 b4 ltd
- swaluda
25 Jul 2013 08:15 #598177
by swaluda
Replied by swaluda on topic bs34 and bs36 Air Needle Jets
Gonna post pics of bs 36's. gottem dippin in gunk and gotta run carb cleaner thru em. Need $150.00 to get my money back, includes shipping. Give me a couple days and i'll put em up in pics. 3 kids got me runnin.......Stan
