KZ 1000 carb sync gets a crazy hi idle
- Smokin Sam
16 Jul 2013 17:10 #596791
by Smokin Sam
KZ 1000 carb sync gets a crazy hi idle was created by Smokin Sam
Greetings from a new member in Smithers BC. It's nice to have a place like this to bounce a few ideas around. I am struggling with a friends 79 KZ 1000. I am attempting to sync the carbs, a job I have done successfully on many other bikes. It seems like the idle goes up to about 3000 rpm as soon as the carbs come into sync. We have checked, fixed and retested air leaks at the manifolds, the advance unit is free, we have removed the cables and the linkage is free. There is a gap at the throttle stop so it is backed out as much as possible. The idle will NOT come down. The two right side cyls (1&2)seem to wanna be a little low on the gauges when it will idle at the right speed. I'm wide open to ideas if anyone has any.....
- Thank you received: 2829
16 Jul 2013 17:22 #596796
by 650ed
Replied by 650ed on topic KZ 1000 carb sync gets a crazy hi idle
Did this problem just start recently? Were the carbs worked on? If they were, the problem could be the result of someone adjusting the slide height (carb bench sync) without having the throttle stop adjuster set near the middle of its range. If that it what happened the throttle stop knob will not lower the slides. Have you tried turning the throttle stop several turns in and then adjusting every sync screw an equal number of turns to lower the slides toward the closed position? This might let you then use the throttle stop to adjust the idle up and down. Ed
The following user(s) said Thank You: Smokin Sam
- Smokin Sam
16 Jul 2013 17:39 #596803
by Smokin Sam
Replied by Smokin Sam on topic KZ 1000 carb sync gets a crazy hi idle
That sounds like the problem all right. This is a "new to me" bike with previous issues. I'll give it a try and will post up some results. Thanks.
- Smokin Sam
18 Jul 2013 15:43 #597137
by Smokin Sam
Thanks for the great advice. Once it cooled down (and so did I lol) I tried it again and got it. I still have the two right cyls a little off of the other two but it seems to want to be there and runs great now.
18 Jul 2013 16:09 #597139
by 650ed
Glad it helped! Ed
- zukdave
- Thank you received: 229
18 Jul 2013 20:52 #597188
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic KZ 1000 carb sync gets a crazy hi idle
Did you do a mech. sync first ?
Don't know what carbs you have but on my VM29's
the number 2 carb is the lead carb.
You set the number 2 carb mech. sync that is the base setting
other three set to match #2 carb.
When I did mine I couldnt get them right I'd
run out adjustment on at least one then read a deal on I think
the Old school performance site about set #2 first.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Smokin Sam
19 Jul 2013 13:37 #597306
by Smokin Sam
Awesome! I think that could be the info I needed. I was trying to set them to #3. I'll try it again with this new info.
