- Thank you received: 80
Carb ID Assistance
- CoreyClough
- GPz550 Addiction
16 Jul 2013 12:20 - 16 Jul 2013 19:23 #596746
by CoreyClough
'85 GPz550(ZX550-A2)
Carb ID Assistance was created by CoreyClough
A friend of mine sent me some carbs, he had on his 1982 GPz550, and knowing what carbs came on all years GPz550, I am puzzled that these matched right up to the stock intakes. I thought they were RS Carbs, but after a call to Sudco with pictures sent, I was informed because of the tops as they are, they are more than likely a factory set. I don't have any of the main jet sizes, as I haven't removed a bowl for this. The slides are flat, but I have no idea what bike came from. Any help would be greatly appreciated.
Last edit: 16 Jul 2013 19:23 by CoreyClough.
- loudhvx
- Thank you received: 1616
16 Jul 2013 15:07 #596771
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Carb ID Assistance
Wow. That's pretty crazy looking. I've never seen that type of carb on any Suzuki or Kaw. Did either make an inline-4, 4-stroke watercraft or snowmobile?
It looks old, otherwise I'd say it may be from a newer bike, but I thought anything from about 82-83 up would be CV's.
1981 KZ550 D1 gpz.
Other links.
The following user(s) said Thank You: CoreyClough
- CoreyClough
- GPz550 Addiction
16 Jul 2013 16:19 #596784
by CoreyClough
Replied by CoreyClough on topic Carb ID Assistance
Thanks for the reply Lou. I don't know anything about these. Requires a pull and a push cable, but no inflomation written of the carbs would help me to identify them.
- gd4now
- Denco where did you go?
- Thank you received: 444
16 Jul 2013 16:49 #596789
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Carb ID Assistance
I do not know for sure but they look like a set of Mikuni RS carbs. Are there no other ID marks stamped on the carbs - on the flanges maybe?
1977 KZ650 B1
- CoreyClough
- GPz550 Addiction
16 Jul 2013 17:55 #596809
by CoreyClough
Sudco confirmed that they are not RS Carbs, or any other special Mikuni Carbs.
- Cynjut
- Thank you received: 26
16 Jul 2013 18:39 #596814
by Cynjut
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
Replied by Cynjut on topic Carb ID Assistance
The pictures on-line that I found that were closest make them to be Mikuni RS-38 Flat Sides. Using an inside caliper, measure the 'engine side' aperture and tell us what the measurement is. That might help us get closer.
1977 KZ-1000 A1
- CoreyClough
- GPz550 Addiction
16 Jul 2013 19:22 - 16 Jul 2013 19:23 #596819
by CoreyClough
I measured the inside diameter of the engine side outlet, and came up with 1.06 inches or 26.924 millimeters.
- Motor Head
- Thank you received: 391
16 Jul 2013 23:38 #596863
by Motor Head
Replied by Motor Head on topic Carb ID Assistance
I've seen some listed on Feebay that look like that. GSXR 750 carbs from UK maybe. Not sure about CAN, but thats also a possibility.
- Cynjut
19 Jul 2013 00:42 #597235
by Cynjut
1977 KZ-1000 A1
According to Mikuni, a lot of the flat side carbs were used on Harleys.
1977 KZ-1000 A1
- Roadflyer
- Thank you received: 13
19 Jul 2013 12:52 #597299
by Roadflyer
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
Replied by Roadflyer on topic Carb ID Assistance
they may be from a gsxr 600
- StreetfighterKz
- Thank you received: 117
19 Jul 2013 13:38 #597309
by StreetfighterKz
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Replied by StreetfighterKz on topic Carb ID Assistance
No eBay APP ID and/or Cert ID defined in Kunena configurationFound these:
Maybe you can contact the seller and see if they have more info?
Later, Doug
Later, Doug
1989 Vmax
- CoreyClough
- GPz550 Addiction
19 Jul 2013 21:07 - 22 Jul 2013 16:01 #597369
by CoreyClough
Thanks for that information Doug. Looks like TM Flatslides according to Sudco Catalog Dimensions. I will call Mikuni directly or email them Monday...
Last edit: 22 Jul 2013 16:01 by CoreyClough.
