Pilot Jets 1977 KZ1000
- davew9wrl
16 Jul 2013 09:14 #596723
by davew9wrl
Pilot Jets 1977 KZ1000 was created by davew9wrl
Guys, I have been working on a 77 KZ1000A, it was all stock. I have added KN air filters and a MAC exhaust. After a few tries at increasing the main jets to 130's it seems to be running at the correct mixture, runs great, except at idle, it's a little erratic. When it's cold say from start up till about 15 minutes of riding it will idle down and die if I don't use the throttle. I can adjust the idle screw, but then when it gets good and warmed up it will idle to high. The carbs currently have pilot jets installed they are #17. Seems to me that this needs to be increased to make up for the improved air flow.
Questions are.
1. Am I correct? do I need larger pilot jets?
2. If I am correct what size jet would you think I should try?
Questions are.
- roy-b-boy-b
- Thank you received: 103
16 Jul 2013 16:30 #596786
by roy-b-boy-b
Replied by roy-b-boy-b on topic Pilot Jets 1977 KZ1000
Bump the slow jet up to 20.
The following user(s) said Thank You: davew9wrl
