82 1100 BS34 Carb Overflow Hoses
- swaluda
15 Jul 2013 09:35 #596575
by swaluda
82 1100 BS34 Carb Overflow Hoses was created by swaluda
Still tryin to fiqure this out. The middle hose goes to gas tank, the other 2 on each side are just dangling unplugged, does this seem RIGHT, Stan
- Motor Head
- Thank you received: 391
15 Jul 2013 10:15 #596579
by Motor Head
Replied by Motor Head on topic 82 1100 BS34 Carb Overflow Hoses
Carb Overflow hoses are off of the Bottom of the Fuel Bowls. They are there to make the Gas drain down to the ground with out hitting a Hot engine.
If your talking about something else, post pictures. Are you talking Vacuum lines, or Fuel Feed hoses?
Overflow is easy, each bowl gets one hose, going over the backside of the motor near the swing arm. Tie them together with a Zip Tie, and then there is a small tab/ bracket to route them through. Hang them down a few inches below the motor.
- swaluda
15 Jul 2013 10:35 #596582
by swaluda
Replied by swaluda on topic 82 1100 BS34 Carb Overflow Hoses
I have 3 hoses on the fuel rail, 1 goes to the gas tank, and I don't know how the others connect
- Thank you received: 1656
15 Jul 2013 11:11 - 15 Jul 2013 11:15 #596585
by martin_csr
Replied by martin_csr on topic 82 1100 BS34 Carb Overflow Hoses
I'd guess the 2 on either side of the fuel line are the vents. Usually, there are a coupe of vent tees between the 1-2 & 3-4 carburetors and they are higher up on the carb bodies than the fuel fittings.
If the bike has a vacuum petcock, then there should be a vac line connected to the petcock vac port & to a vac port on one of the carbs - usually #2.
Last edit: 15 Jul 2013 11:15 by martin_csr.
The following user(s) said Thank You: swaluda
