- Thank you received: 27
BS34 Pilot Jets
- havakaw
13 Jul 2013 17:48 #596321
by havakaw
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
BS34 Pilot Jets was created by havakaw
OK...So the last guy to have these appart flattened the screwdriver groove in them,and now I can't get them out.It runs good,but I'd like to put in the larger size that came with the rebuild kits,because of the GPZ cams and 1136 kit.Any ideas other than taking them to the machine shop and having them try to extract them?
'80 KZ 750 LTD-H
- turboking
- Thank you received: 106
13 Jul 2013 18:39 #596325
by turboking
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Replied by turboking on topic BS34 Pilot Jets
:pinch: as a last resort I've drilled the pilots so I could use a very small ez out to remove them :pinch: of course they are ruined from drilling....... :huh:
1985 GS 1150E
1983 GS 1100E
- mtkawboy
- Thank you received: 16
14 Jul 2013 18:14 #596493
by mtkawboy
Replied by mtkawboy on topic BS34 Pilot Jets
If you can find a reverse drill bit that small try putting it in a tap holder from a tap & die set and heat the area up that the pilot jet screws into and try to turn it out by hand. If you can find a small enough EZ-out try the same thing. Nothing to lose, its no good like it is.
