1984 Gpz 1100 Correct throttle cable
- Statorhed
12 Jul 2013 23:48 #596259
by Statorhed
1984 Gpz 1100 Correct throttle cable was created by Statorhed
Hi guys ,Recently swapped out my F/I for a set of B34 Mikuni carbs . The original f/I throttle cable is about 2 inches short. What substitute cable can I use? The carbs use a single pull type cable. Also carbs are off a 1984 GPZ 750 that are jetted for a KZ 1100. Thanks Jeff
- havakaw
- Thank you received: 27
13 Jul 2013 17:38 #596319
by havakaw
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Replied by havakaw on topic 1984 Gpz 1100 Correct throttle cable
Use one from an '81-4 KZ1100A.Just be careful with how the oil cooler lines run.You might have to tie them back/reroute them a little to keep them from hanging up the carbs.You REALLY don't want the carbs hanging up at half throttle.Also,if the cooler lines are old and brittle,look into having them repaired/replaced by a local hydraulic line/fitting shop.They are getting scarce,and the new OEM ones i got were $150 each.But I also got a cut set with the block fitting and cooler.(as spairs).I'm taking them down to a local hydro-power place to see if they can't use the fittings and replace the rubber.
'80 KZ 750 LTD-H
The following user(s) said Thank You: Statorhed
