Kei hin carbs gasket???
- DBICK666
- 1983 kz750 ltd f-1 (shaft)
11 Jul 2013 15:36 #596022
by DBICK666
Kei hin carbs gasket??? was created by DBICK666
Hi I need to rebuild my carbs I olny found an o ring and not a gasket do I need a gasket for a rebuild? Or is there a gasket for it also looking for valve cove gasket. When I bought it all the carbs and valve cove has liquid gasket I need to get that shit off and work on a couple things thanks.
- Thank you received: 2829
11 Jul 2013 16:01 #596025
by 650ed
Replied by 650ed on topic Kei hin carbs gasket???
Looking at the diagram on Kawasaki.com it appears that all the carb o-rings are still available, so any dealer can get them for you. I didn't see anything marked as a gasket. Ed
Attachment 00000_2013-07-11.jpg not found
- DBICK666
11 Jul 2013 18:23 #596048
by DBICK666
Replied by DBICK666 on topic Kei hin carbs gasket???
ok thanks i thought it showed an oring and a gasket in the book but might have been 2 different carbs
- Motor Head
- Thank you received: 391
11 Jul 2013 23:06 #596098
by Motor Head
Replied by Motor Head on topic Kei hin carbs gasket???
No eBay APP ID and/or Cert ID defined in Kunena configurationYou can by rebuild kits for your carbs pretty reasonable.
I've bought from this seller several times with great service.
- havakaw
- Thank you received: 27
13 Jul 2013 17:45 #596320
by havakaw
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Replied by havakaw on topic Kei hin carbs gasket???
If you are going to rebuild the carbs,get a set of Stainless Steel Allen bolts (socket head cap screws)for the covers and bowles.TRUST me on this one.AND use a little High Vacuum Grease on the bowl O-Ring to hold in place in the bowl groove.Life will be SOOOOOO much easier for you. And throw in a set of 132 Main jets.Make it go faster!! :woohoo:
'80 KZ 750 LTD-H
- DBICK666
14 Jul 2013 13:25 #596442
by DBICK666
Cool thanks also got a set of 54mm ari filters I know they'll for on the cb750 I'm working on will they fit on the kz750 if not no big deal still waiting for them to get here
- undiablo
- Thank you received: 64
14 Jul 2013 16:59 #596477
by undiablo
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Replied by undiablo on topic Kei hin carbs gasket???
Check my post on keihin cv34 gaskets:
www.kzrider.com/forum/3-carburetor/57641...at-bowl-oring-gasket
