- Thank you received: 2
Tool to adjust idle mixture screw?
- anotherZ
09 Jul 2013 19:13 #595732
by anotherZ
79 KZ 1000 LTD
Saved it from becoming a drag bike
Smaller tank
Tool to adjust idle mixture screw? was created by anotherZ
It is such a painful process to adjust the idle screw, especially on carb number 2 with the accelerator pump. Somewhere I have seen a plastic know stuck on the idle screw to make it adjustable by hand. Does anyone know of this? Any other homemade tools to recommend? Bike is a 79 lTD 1000. Thanks!
79 KZ 1000 LTD
Smaller tank
- elfmagic17
- Thank you received: 24
09 Jul 2013 23:37 #595774
by elfmagic17
Kenny Hicks
74 Honda CB550
Replied by elfmagic17 on topic Tool to adjust idle mixture screw?
www.z1enterprises.com/ItemDetails.aspx?i...+Tool&item=MP08-0119
Like this? Should work but never used one.
Kenny
Kenny
Kenny Hicks
74 Honda CB550
- CoolerKing
- Thank you received: 3
10 Jul 2013 10:57 #595811
by CoolerKing
1978 KZ650-C2
1976 KZ400D-3 (sold)
Replied by CoolerKing on topic Tool to adjust idle mixture screw?
1978 KZ650-C2
- Cynjut
- Thank you received: 26
10 Jul 2013 12:26 #595816
by Cynjut
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
Replied by Cynjut on topic Tool to adjust idle mixture screw?
I built a 'screwdriver' from an old spoke - use the knurl with a 1/4" of the spoke sticking, ground down to a flat tip about a millimeter thick and the width of the spoke.
1977 KZ-1000 A1
- anotherZ
10 Jul 2013 12:51 #595823
by anotherZ
79 KZ 1000 LTD
Smaller tank
Replied by anotherZ on topic Tool to adjust idle mixture screw?
Good suggestions, thanks! I have been experimenting with a ground down bit inside a plastic tube that fits right over the idle screw. That makes it easier to access the carb with the accelerator pump. will post a pic, when I have it ready.
79 KZ 1000 LTD
Smaller tank
