KZ750 Shaft dies on full throttle from idle
- rboutin2
09 Jul 2013 16:29 - 09 Jul 2013 16:30 #595718
by rboutin2
KZ750 Shaft dies on full throttle from idle was created by rboutin2
I just finished cleaning the carbs out. Bike has 9400 miles. Everything is cleaned, float needles dont have a groove in them. Float levels were way off. Fuel was leaking into carbs (bench test with clear tube, carbs level.) 2 of the carbs were almost a 1/2 inch above the gasket surface. I got them allset so no leaks. Bike did not have die from full throttle before cleaning. Did leak gas before cleaning. No leaks in carb boots (propane torch method). Edit: Bike runs otherwise perfect.
Last edit: 09 Jul 2013 16:30 by rboutin2. Reason: more info
- Thank you received: 2829
09 Jul 2013 16:43 #595719
by 650ed
Replied by 650ed on topic KZ750 Shaft dies on full throttle from idle
What are you using for air filtration? Ed
- rboutin2
09 Jul 2013 19:05 #595730
by rboutin2
Replied by rboutin2 on topic KZ750 Shaft dies on full throttle from idle
Everything on the bike is stock.
- rboutin2
12 Jul 2013 01:12 #596116
by rboutin2
I figured it out. Apparently the air filter was not the right one, and it was making the bike run super lean. Tried my filter from my 82 kz650 and it worked like a charm.
12 Jul 2013 07:38 #596131
by 650ed
That will do it. Good find / good fix. Ed
