- Thank you received: 33
kz550 start problem
- nickleo373
07 Jul 2013 19:47 - 07 Jul 2013 19:50 #595433
by nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
kz550 start problem was created by nickleo373
Hey everyone.
I've been fixing up an 81 kz550 ltd. So far I've installed a new battery new spark plugs and I converted the pod filter the previous owner installed back to the air box. I also added new oil, oil filter, and gas. I put it all back together and tried to start it and the bike won't run with the air box cap on without cranking the starter motor for a few seconds on full choke. I bought the air boxbecause the bike didn't run well with the pods but it does turn over easily and idle. With the air box installed the starter motor just cranks and nothing else happens. I thought it could be the jets in the carbs but they were too frozen up to see the size numbers on the jet. I'm out of ideas. Does anyone know what this could be?
Thanks
Nick
Thanks
Nick
1981 KZ550C LTD
Last edit: 07 Jul 2013 19:50 by nickleo373. Reason: update
- Thank you received: 2829
07 Jul 2013 22:25 #595456
by 650ed
Replied by 650ed on topic kz550 start problem
It's quite possible that the previous owner fiddled with the jetting when he installed the pods, so you will need to see what he has done. I would soak the jets with Kroil for a few days and then see if they will come out. Ed
