- Thank you received: 20
Another "revs won't come down thread"
- DesertKZ
07 Jul 2013 19:40 - 07 Jul 2013 20:02 #595432
by DesertKZ
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
Another "revs won't come down thread" was created by DesertKZ
Been searching on this site for about an hour and can't find what I'm looking for so here goes.
Bike starts cold in under two seconds (choke) and I can rev it normally, revs come down immediately. With choke off and at idle, I will rev the bike and the revs are slow to come down. Back on choke, it revs up and down perfect.
Here's what's new:
New Carb Holders
New Motion Pro Cables
New K&N pods (bike didn't come with a box)
Rebuilt carbs last fall
Air screws 1.5 out
New rings, valve seals, timed correctly
Thoughts? I know it kind of sounds like an air leak but I'm baffled because at choke it revs fine.
1979 KZ1000st
Here's what's new:
New Carb Holders
Air screws 1.5 out
1979 KZ1000st
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
Last edit: 07 Jul 2013 20:02 by DesertKZ.
- Thank you received: 2829
07 Jul 2013 22:29 #595459
by 650ed
Replied by 650ed on topic Another "revs won't come down thread"
Your jetting may be wrong (too lean) for pods. I would check the jetting and then hope you will get jetting suggestions from someone on this site with the same engine, carbs, & pods who has gotten their bike to run ok (if there is such a person). Otherwise consider buying and installing an airbox and return the carbs to the stock jetting or be ready to do some jetting experimenting for the pods. Ed
- DesertKZ
07 Jul 2013 23:46 #595476
by DesertKZ
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
Replied by DesertKZ on topic Another "revs won't come down thread"
Sounds good thanks for the insight. There's a local old bike shop and the owner suggested the jets I'm currently running.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
- mtkawboy
- Thank you received: 16
09 Jul 2013 14:49 #595701
by mtkawboy
Replied by mtkawboy on topic Another "revs won't come down thread"
What mains & pilot jets are you running ? Id suggest you buy a dynojet kit for your bike if you insist on keeping the pods. Personanly Id put the stock airbox back on. At the very least tell us what jets the mystery man told you to run. Pods are a nightmare for do it yourself jetting.
- mtkawboy
09 Jul 2013 14:53 #595703
by mtkawboy
I made 1 search for KZ1000ST jetting for pods for any date & came up with this
kzrider.com/forum/forum-search?q=KZ1000S...te=all&childforums=1
- DesertKZ
09 Jul 2013 16:06 #595714
by DesertKZ
Stock pilots 15's and am running 120's (stock 110's) for mains. Plugs were looking good up until the motor rebuild. Valves are in spec. I don't have the box, bike never came with it. I turned the idle down a tad after the bike was sufficiently warmed and it seemed to help. Thanks for the replies.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
mtkawboy wrote: What mains & pilot jets are you running ? Id suggest you buy a dynojet kit for your bike if you insist on keeping the pods. Personanly Id put the stock airbox back on. At the very least tell us what jets the mystery man told you to run. Pods are a nightmare for do it yourself jetting.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
