1980 KZ750 LTD Carbs float heights keep changing
- astark
05 Jul 2013 14:48 #595159
by astark
1980 KZ750H LTD
1980 KZ750 LTD Carbs float heights keep changing was created by astark
Hi, I've been having some trouble with my KZ750 LTD lately. It has the Keihin CV34 carbs on it. A few days ago I was riding it and it started leaking a large amount of fuel out of one of the carbs. I pulled them off and the needle wasn't stuck, so I compared it to another one of the carbs and found that the float was off. I adjusted it and the leak was fixed, I went on a few rides and everything was fine. Today I started it up and that same carb just began leaking again. I haven't had time to pull them apart and take a look at it yet, I will later today, but does anyone have any ideas why this would happen. What could cause the float height to keep getting screwed up every couple of rides? Thanks in advance.
1980 KZ750H LTD
- upncummr
- Thank you received: 16
05 Jul 2013 15:02 #595160
by upncummr
Replied by upncummr on topic 1980 KZ750 LTD Carbs float heights keep changing
Maybe the float needle is intermittently sticking.
- kzcafe750_24
05 Jul 2013 15:16 #595163
by kzcafe750_24
1981 Kz 750-4 LTD - Wiseco 810 Big Bore,Ported cylinder head, GPZ 750 Cams,Dyna Ignition(DynaS,Green Coils,DRL400 2stage Revlimiter), RC 4 into 1 fitted with Yoshi muffler, ZR550 Swing arm, ZR550 Rear Rim, ZX750turbo front end SuperFlo Dyno Tuned- 68WHP&43WTq(ftlbs)
1986 Honda Rebel 250 (Stock)
1985...
Replied by kzcafe750_24 on topic 1980 KZ750 LTD Carbs float heights keep changing
My question would be, do u have a fuel filter inline, because sometime particles can wedge in between the float valve and seat, try blowing throuh the line with the floats off to clean out the fuel circuit. I personally have also had the overflow tube crack and leak fuel out of the overflows at a good rate.
1985...
- astark
05 Jul 2013 16:26 #595171
by astark
1980 KZ750H LTD
Replied by astark on topic 1980 KZ750 LTD Carbs float heights keep changing
Thanks for the quick responses. I've checked the float tube, and there's no cracks. I do have a fuel filter, but I'll double check the float needle. I just rebuilt the carbs, so they're brand new float needles, I've heard that if it is sticking I can shave it down a bit. Any advice on that? I just got home and am about to tear into them, so I'll let you know how it goes.
1980 KZ750H LTD
- upncummr
05 Jul 2013 16:30 #595173
by upncummr
650ed had a good suggestion in this thread regarding spraying carb cleaner into the float needle orifice while the carbs were still on the bike.
www.kzrider.com/forum/3-carburetor/58974...ts-or-needles#595156
- astark
10 Jul 2013 12:38 #595817
by astark
1980 KZ750H LTD
Thanks, I figured out that the float needle was sticking in the seat. I ended up just sanding off a bit of the edges of the needle and haven't had any problems since.
Thanks
Thanks
1980 KZ750H LTD
