- Thank you received: 33
kz550 won't idle with airbox cap
- nickleo373
02 Jul 2013 20:51 #594776
by nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
kz550 won't idle with airbox cap was created by nickleo373
Hey everyone.
I just got the air filter cap for my 81 kz550 today after removing the pods and putting the air box back on. The bike will start and idle with the cap off but when I screwed it in the bike would idle poorly for a few seconds and die. It also dies when I twist the throttle. The previous owner put pods on the bike and when I took them off they had a small amount of rust on them as if they were being run on the bike, however with the pods installed I couldn't give the engine more than 1500 rpms or it would stall. I figured the carbs weremt jetted to run with the pods and bought the air box but it seems like with the air box the carbs aren't getting enough air. Any suggestions would be appreciated
Thanks
Thanks
1981 KZ550C LTD
- Thank you received: 2829
02 Jul 2013 21:46 #594783
by 650ed
Replied by 650ed on topic kz550 won't idle with airbox cap
I would start by checking the current jetting. If it's not stock I would set it to stock and see how it runs. Ed
- nickleo373
02 Jul 2013 22:31 #594792
by nickleo373
1981 KZ550C LTD
Replied by nickleo373 on topic kz550 won't idle with airbox cap
Thanks Ed.
This is probably going to be a stupid question but I'm new to motorcycles and mechanics in general. How do I get the jets out of the carbs to check the sizes?
1981 KZ550C LTD
02 Jul 2013 22:38 #594794
by 650ed
You probably should have the manual before you start that process as it contains much info that will be helpful. Ed
