1976 kz900 z-1 what carbs should be on it?
- bwill166
02 Jul 2013 11:38 #594707
by bwill166
1976 kz900 z-1 what carbs should be on it? was created by bwill166
Hello all. My new project is a 1976 z-1 (kz900). My carbs are marked mikuni but cant find a model number to order kits for them. Any help would be greatly appreciated. Could use a good diagram also. Thanks and hope its ridin weather where your at.
- Mcdroid
- Gone Kwackers
- Thank you received: 319
02 Jul 2013 12:27 #594709
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic 1976 kz900 z-1 what carbs should be on it?
If you have the original carbs on the motorcycle and truly have a 1976 KZ900, there should be Mikuni VM26ss carbs on the motorcycle. However, many owners did mix-and-matches with carbs. Look at
www.z1enterprises.com
for a series of photos and diagrams to aid in identifying carbs.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- roy-b-boy-b
- Thank you received: 103
02 Jul 2013 16:53 #594742
by roy-b-boy-b
Replied by roy-b-boy-b on topic 1976 kz900 z-1 what carbs should be on it?
Welcome to the site.
I would try and clean the carbs first. Real good. I have probably had 30 sets of old stuck carbs and have never put a kit in any of them. They are expensive and the only pieces I have seen useful is the float needle seats.
I understand you buying kits if you have only the one set and the carbs are trashed with the disassembly .
The carb numbers are toward the front outside on the one and four carb. Where the carb body is connected to the piece that holds all the carbs together.
- bwill166
03 Jul 2013 11:25 #594860
by bwill166
Replied by bwill166 on topic 1976 kz900 z-1 what carbs should be on it?
Thank you for the replys. Z1 is a wealth of knowledge. They are the original vm26's according to the info there. Ive sprayed them several times over the past couple days with penetrating lube and still wont move. Ill keep after it. Thanks again.
