- Thank you received: 265
Boiling carbs
- KZB2 650
30 Jun 2013 17:38 #594503
by KZB2 650
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Boiling carbs was created by KZB2 650
Having problems with a off idle stumble so I striped the carbs down and am ready to clean the pilots out and the bodys. Been reading Barryman's carb soak has lost a lot of power over the years and that boiling the bodies in lemon juice, vinegar and water for 45 min then clean water for 30 really does a great job.
Would follow that up with Patton's way of holding passages off while blowing air and cleaner through all.
Will pick up the gal of carb soak if you really think its better (want it clean) but I already have the Vin, lemon and water, not to mention about 5 cans of spray cleaner and a good enough compressor.
Thanks.
Thanks.
1978 KZ650 b-2
- Thank you received: 1656
01 Jul 2013 11:54 #594590
by martin_csr
Replied by martin_csr on topic Boiling carbs
The original Berryman's formula may still be available - I believe it's their "professional" parts cleaner - all of the plastic & rubber parts must be removed. Berrymans provides msds info.
Hot water & PineSol should be a good cleaner to use, as pinesol is non-corrosive. I used it to clean a fuel valve.
- mopguy
- Thank you received: 168
01 Jul 2013 20:20 - 01 Jul 2013 20:22 #594627
by mopguy
Replied by mopguy on topic Boiling carbs
I must have cleaned by boiling and soaking my BS34mm Mikunis with Pinesol and other green stuff six times and had no luck, finally I got industrial strenght carburetor and cold parts cleaner from an auto supply store called KLEEN FLO and I cant believe the crap that came out of them, no wonder they did not work!!
Last edit: 01 Jul 2013 20:22 by mopguy. Reason: added
- Motor Head
- Thank you received: 391
01 Jul 2013 22:18 #594648
by Motor Head
Replied by Motor Head on topic Boiling carbs
Be careful of the coating on the slides. There was a post last year of a member who soaked his slides in something and took off the coating.
