- Thank you received: 33
81 kz550 high rpms
- nickleo373
30 Jun 2013 16:22 #594496
by nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
81 kz550 high rpms was created by nickleo373
Hey everyone.
I just put my airbox back on my 81 kz550 after the last owner changed to pods without rejetting. The bike will start up and the rpms start fine but if i add throttle they shoot way up and stay there even after the throttle is pulled back in. I thought the airbox was the problem but i guess not. My intake boots and air box boots are brand new and installed tightly. Im at a loss. Anyone know what might be causing this?
1981 KZ550C LTD
- Thank you received: 2829
30 Jun 2013 19:29 #594516
by 650ed
Replied by 650ed on topic 81 kz550 high rpms
To totally eliminate the possibility of it being a throttle control or cable problem you may want to try this as a test - disconnect the throttle cables at the carbs; start the bike; use your hand at the carbs to momentarily bump up the throttle; let go and see if the idle comes back to normal. If it does, there's an issue with the cables, cable routing, or throttle control; if the idle stays high, you now know for sure it is unrelated to the throttle control or cables, so those variables have been eliminated from the troubleshooting process. Ed
- nickleo373
30 Jun 2013 19:45 #594517
by nickleo373
1981 KZ550C LTD
Replied by nickleo373 on topic 81 kz550 high rpms
Thanks ed. I'll give it a shot tomorrow
1981 KZ550C LTD
- Thank you received: 2098
01 Jul 2013 00:23 #594545
by Patton
Replied by Patton on topic 81 kz550 high rpms
Would also double-check fitment and tightness of the clamps that hold the carbs inside the carb holders.
A loose or ill-fitted clamp could cause an air leak.
- nickleo373
02 Jul 2013 00:53 #594673
by nickleo373
1981 KZ550C LTD
Thanks for the reply Patton. I was spraying the carb cleaner around the boots to look for vacuum leaks and both the intake boots and the air box boots are leaking because the engine revved up to 5000 rpms while spraying. Both the intake and airbox boots are brand new and the intake side is screwed onto the carbs at the head and at the carbs as tight as they can go. Is there anything I can do to stop these leaks? Also would you recommend keeping the spring type clamps that come connected to the factory kz550 air box or would you recommend buying new clamps similar to the screw on ones that hold the carbs to the intake?
1981 KZ550C LTD
03 Jul 2013 10:54 - 03 Jul 2013 11:00 #594852
by Patton
To double-check for confirmation of air leak in carb holder area --- at lowest sustainable idle rpm (perhaps about 1000 rpm), could spray each carb holder with WD40 while watching for exhaust smoke (indicating that WD40 is being ingested into the cylinder).
Possibly a vacuum cap/plug is cracked or torn or loose-fitting.
Would continue using the stock spring type clamps for holding the air box hoses onto the carbs.
Might be mistaken, but thinking the stock hose is molded for placement of the spring.
An air leak at the carb holder -- engine side of the carbs -- usually has a more dramatic effect than an air leak at the air hose connection or through an ill-fitted or torn air hose.
nickleo373 wrote: Also would you recommend keeping the spring type clamps that come connected to the factory kz550 air box or would you recommend buying new clamps similar to the screw on ones that hold the carbs to the intake?
Last edit: 03 Jul 2013 11:00 by Patton.
