- Thank you received: 2
throttle mix screws stuck in limbo
- danger_bandito
- Live fat, die young!
As much as I agree with the term "YOLO," I equally hate it.
1981 KZ440LTD-A2 - "Calamity"
- Thank you received: 2098
danger_bandito wrote: Someone sealed my throttle mix screws behind some strong-ass sealant, and thick metal caps on top of that. Until these caps come off, I cannot access the throttle mix screws. They're in there good, too. Any Ideas?
One technique to remove an anti-tamper cap is to drill a hole barely through the center of the cap, without drilling into and damaging the underlying pilot screw.
Start the tip of an appropriately sized metal screw into the hole, until firmly inserted. Then grip the screw with pliers and pull out the cap.
- danger_bandito
- z1kzonly
- Thank you received: 542
Just cruisin by and seen this question.danger_bandito wrote: Someone sealed my throttle mix screws behind some strong-ass sealant, and thick metal caps on top of that. Until these caps come off, I cannot access the throttle mix screws. They're in there good, too. Any Ideas?
Do not see a pic or know what type, model, size carb your taking about?
I see you live close to Washington DC.
Maybe Nobamas Green inititve coverts came out and infiltrated your garage, turned the screws all the way lean. plugged them so you could not mess with them. that will save the planet! Is your 2-cycle weed wacker missing also?
Just a thought?
- danger_bandito
