Carb sync issues. high vacuum on #1.
- jp-15
28 Jun 2013 21:15
Hi everyone. I suppose this is my introductory post. I've been lurking the forums for a couple months, taking advantage of the search option. I can't seem to figure this one out though. The carbs are vm26's and do not have the air screw. Only the pilot screw. I have this at 2 turns out. 20 pilots and 122.5 mains. The motor is a 900. Valves were done last spring. Carburetors were gone thru this spring.
When I go to put my homemade sync tool on, #1 is drawing way to much vacuum. I BELIEVE this tells me vacuum leak, correct? I've been pulling my hair out. I checked the choke plunger, new carb holders, float levels checked, checked all rubber orings in carbs twice. Still, too much vacuum @#1. Also plugs are black as can be @ cylinders 1-2-&3. #4 is a good brown color. How can #1 plug be black, but have a vacuum leak?(so I think). Any help here would be great. Needle & seat?
Bike has dyna s with dyna green coils. Timing is dead nuts. Have yet to do the coil mod, but wouldn't 4 be black too if ignition was the problem here? I was getting an off idle stumble bad at 1/8 throttle. Also getting black smoke @ idle telling me too rich.
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
Dynatek S w/Green Coils.
Winter Project= 10.25:1 1015 cc kit w/ Web cams and Refurbished head. 33 smoothies hopefully.
903cc
K&N Pods
4-1 V&H
VM26's
- jp-15
Re: Carb sync issues. high vacuum on #1.
28 Jun 2013 21:17
The bike is running individual pods and a 4-1 Vance and Hines as well.
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
903cc
K&N Pods
4-1 V&H
VM26's
28 Jun 2013 22:17
If the #1 carb slide is closed more than the others the vacuum at the carb holder will be greater than the others. I doubt that it is a vacuum leak; if it was I would expect the vacuum at the gauge to be lower, not higher, because some vacuum would be drawing through the leak rather than the gauge. I would sync the carbs and see how well the bike idles. Ed
- jp-15
28 Jun 2013 22:30
As soon as I fire the bike it wants to pull the trans fluid from my nanometer up to #1 intake and gives me lots of air in the lines. Do I need restrictors in the lines?
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
903cc
K&N Pods
4-1 V&H
VM26's
- taildragger1197
28 Jun 2013 22:54jp-15 wrote: Do I need restrictors in the lines?
YES...definitely.
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
- jp-15
29 Jun 2013 12:22
What is the best thing to use? Pilot jets?
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
903cc
K&N Pods
4-1 V&H
VM26's
- jp-15
01 Jul 2013 07:56
Bump
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
903cc
K&N Pods
4-1 V&H
VM26's
- nitrokrumpt
- she just looks rough now
01 Jul 2013 13:04
wtf is bump
1982 kz750-n1 spectre
- slayer61
- KZR FLAG RELAY CARRIER #62
01 Jul 2013 13:55jp-15 wrote: As soon as I fire the bike it wants to pull the trans fluid from my nanometer
I have done a little bit of vacuum measurement at work and everything seems to be measured in inches of water or inches of mercury... I've never heard of "inches of trans fluid" :dry: :S
01 Jul 2013 14:34Some home-made diy manometers use long clear hoses with ATF inside.slayer61 wrote:jp-15 wrote: As soon as I fire the bike it wants to pull the trans fluid from my nanometer
From KZr FILEBASE:
www.kzrider.com/filebase/doc_download/18...fferential-manometer
- jp-15
02 Jul 2013 02:28nitrokrumpt wrote: wtf is bump
bump= bump the post to the top.
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
903cc
K&N Pods
4-1 V&H
VM26's
- nitrokrumpt
02 Jul 2013 03:44
yea i think i may need to make one my self. can you take a picture of yours?
