- Thank you received: 133
ID this jet (help a noob)
- Topper
22 Jun 2013 16:49 #593507
by Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
ID this jet (help a noob) was created by Topper
So I'm trying to do a little experimentation with my main jet size. After describing the jets to someone over the phone they thought I had "small round" Mikuni jets. So I bought some in the appropriate sizes but they're all wrong.
So what's this tiny main jet called and how do I make sure I order the right part next time?
Attachment jets.jpg not found
1979 KZ750 Twin
- Topper
22 Jun 2013 17:28 #593508
by Topper
1979 KZ750 Twin
Replied by Topper on topic ID this jet (help a noob)
Z1enterprises lists a carb rebuild kit (out of stock) for my bike but IDs the carbs as N100.606 series (not sure what that means)
I see Mikuni "pilot" jets or "low speed" jets that have this number and look right but I don't see any identified as mains.
1979 KZ750 Twin
- gd4now
- Denco where did you go?
- Thank you received: 444
22 Jun 2013 18:50 #593511
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic ID this jet (help a noob)
Are you sure that is a main? That looks more like the N100.606 pilot jet.
The BS 38s used on the kz750 twins are different in that both the pilot and main jets are screwed into the bowl and not the carb body like the the other BS type carbs are.
1977 KZ650 B1
- Topper
22 Jun 2013 19:37 #593515
by Topper
1979 KZ750 Twin
Yeah, this came out of my float bowl just above the drain screw. It's the main jet. The pilot jet is also in the bowl, but you get to it from the top of the bowl.
If you look at the carb rebuild kit from Z1 you'll see both jets pictured. The long one is the pilot and the little stubby one is the main.
www.z1enterprises.com/ItemDetails.aspx?i...-1979&item=KL18-2464
I'm looking to swap my 125 main with a 120.
So all the N100.606 Mikuni "pilot" or "slow" jets are actually what I want after all?
1979 KZ750 Twin
- Topper
28 Jun 2013 21:46 #594288
by Topper
1979 KZ750 Twin
So to help any other's with these carbs, the main jet is actually a pilot or "slow speed" jet. Picked up a couple and they fit perfectly.
1979 KZ750 Twin
