- Thank you received: 17
carb cleaning
- dkoz
21 Jun 2013 15:08 #593390
by dkoz
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
carb cleaning was created by dkoz
Is it possible to just clean jets with carbs left on bike??
Bike will only run in full choke.
Had to clean failed tank liner out of tank
Cleend gumed up jets reinstalled...same problem..
Checked coils OK
Dyna s seems to work at least its in time
..help again !!!???
Checked coils OK
..help again !!!???
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
- bountyhunter
- Thank you received: 337
21 Jun 2013 16:15 #593403
by bountyhunter
Replied by bountyhunter on topic carb cleaning
You could try:
1) Remove tank and rinse with clean solvent
2) Remove/clean petcock
3) Install inline filters
4) Use bowl screws to drain carbs
5) Fill carb bowls with Gumout liquid carb cleaner or similar cleaner. let soak for a couple of days.
6) Remove drain screws. Use carb spray cleaner to hose down through the bowls using the gas inlet and drain hole. Rinse thoroughly.
7) Check fuel levels with clear tube.
- dkoz
21 Jun 2013 16:27 #593406
by dkoz
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
Replied by dkoz on topic carb cleaning
Clear fuel line with in line filters installed...
Nice clean fuel flowing ..
I would probly just yank carbs off than wait a few days..
Maybe I'll try it though is raining here
also after cleaning jets carb cleaner shot 8 feet out so I'm pretty sure jets are OK..
Making me wounded if I had to pull the carbs and maybe shoot cleaner and air through them
Thanks for the suggestion
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
- baldy110
- Thank you received: 512
21 Jun 2013 17:03 #593409
by baldy110
Replied by baldy110 on topic carb cleaning
If your bike only runs with choke on then they are plugged and you cannot clean them properly without removing them. They have to be taken apart and throughly cleaned making sure all the internal passegeways in the carb bodies are clean and clear.
The following user(s) said Thank You: Motor Head
- dkoz
21 Jun 2013 23:21 #593461
by dkoz
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
That's what I'm afraid of doing...
Their stock 78 b2 carbs any one have step by step info ??
Pictures?? I sure would be thankful
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
