kz 1100 carb problems (newb)
- rampimpin
- Spectre1982
- Thank you received: 9
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
- rampimpin
- rampimpin
- baldy110
- Thank you received: 512
- daveo
- Thank you received: 661
1982 KZ1100-A2
- daveo
Would this be your jet-set suggestion for my setup as well? Stock 1100 engine, V&H header, stock air box w/K&N filter, Dyna 2000.
That is how I have the carbs now, with 37 pilots.
1982 KZ1100-A2
- rampimpin
- baldy110
daveo wrote: baldy110
Yes, that is assuming the bikes are in good tune and have no other issues such as electrical, ect.
When I put on both Pods and a 4 into pipe my main jets will be 122.5, pilots #40 and a 1mm washer under each needle. That usually gets me a good running engine. Every bike is different but that should get it running decent.
