Kz1000m feul petcock project
- lucienmaier
19 Jun 2013 15:51 #593086
by lucienmaier
--1981 Kz1000m CSR--
--Converted to 1100CC---
Kz1000m feul petcock project was created by lucienmaier
So I am trying to figure out a way to turn my Vaccum sucking petcock.
to a manual on and off one.
My Petcock just doesn't suck like it used to......
anyway anyone have a hint or idea of how to pull this off...
I would post a pic but they say that posting petcock pics is against the rules
- guitargeek
- Thank you received: 50
19 Jun 2013 16:07 #593089
by guitargeek
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Replied by guitargeek on topic Kz1000m feul petcock project
I glued the diaphragm plunger down and filled passages with Seal All adhesive, just left the priming passage open.
- turboguzzi
- Thank you received: 72
19 Jun 2013 16:17 #593092
by turboguzzi
Replied by turboguzzi on topic Kz1000m feul petcock project
a working auto petcock is actually a nice thing... finding one in good working order or overhauling it is no big deal, there are kits to sort them out
so why go back to stone age?
- lucienmaier
19 Jun 2013 16:27 #593094
by lucienmaier
Replied by lucienmaier on topic Kz1000m feul petcock project
guitargeek: Thanks for the tip I was have way there last night but I guess i did not seal it well enough. what did you use?
turboguzzi: These carbs are horribly out of snyc already. I want to take out all vacuums and dial them in.
- huggybear
- Streetfighter in Training
19 Jun 2013 16:28 #593095
by huggybear
Replied by huggybear on topic Kz1000m feul petcock project
Just replaced the petcock on mine.. z1parts.net 50 Bucks for a new one. Solved my starving issue at higher RPM's...
- Thank you received: 1656
19 Jun 2013 17:01 - 19 Jun 2013 17:01 #593101
by martin_csr
Replied by martin_csr on topic Kz1000m feul petcock project
KZ1000-CSR?
Manual fuel valve.
If the bolt hole spacing is 34mm & I'm pretty sure it is on the CSR: KZR topic - Manual fuel valve option
Vacuum petcock.
The typical rebuild parts are listed as Active at Kawasaki.com, so you should be able to get them from the dealer. Or from Z1Enterprises.com. Z1Ent probably also has a K&L rebuild kit... either the complete kit or the diaphragm kit.
A late model Police bike petcock will probably work. And maybe one from a ZG1000 Concours, but I'm not sure about the Connie?
Manual fuel valve.
Vacuum petcock.
Last edit: 19 Jun 2013 17:01 by martin_csr.
- lucienmaier
20 Jun 2013 12:04 #593215
by lucienmaier
So I was able to seal off the main valve and now I have a manual petcock.
Thanks for all the advice.
