- Thank you received: 33
1980 airbox on 81
- nickleo373
18 Jun 2013 19:18 #592927
by nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
1980 airbox on 81 was created by nickleo373
Hey everyone.
I'm trying to put an airbox back on my 1981 kz550. The previous owner converted it to pods without rejetting the carbs and I dont want to deal with the hassle of rejetting. I bought an airbox on ebay that belonged to a 1980 kz550. Im having a hell of a time getting it onto the carbs. Does anyone know if the 1980 airbox will fit on an 81?
Thanks
Nick
Thanks
Nick
1981 KZ550C LTD
- Thank you received: 2829
18 Jun 2013 19:36 - 18 Jun 2013 19:37 #592930
by 650ed
Replied by 650ed on topic 1980 airbox on 81
According to Kawasaki.com the following bikes use the same airbox:
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-A3 (1982)
KZ550-C1 (LTD) (1980)
KZ550-C2 (LTD) (1981)
KZ550-C3 (LTD) (1982)
KZ550-C4 (LTD) (1983)
KZ550-D1 (GPz) (1981)
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-A3 (1982)
Last edit: 18 Jun 2013 19:37 by 650ed.
- nickleo373
18 Jun 2013 19:48 #592936
by nickleo373
1981 KZ550C LTD
Replied by nickleo373 on topic 1980 airbox on 81
Thanks a lot. I must be trying to install them wrong
1981 KZ550C LTD
18 Jun 2013 19:52 #592940
by 650ed
I know on the KZ650 it's a real tight fit (and impossible without removing the carbs). I only removed and installed mine once and it required a lot of patience and a couple beers. Ed
The following user(s) said Thank You: nickleo373
- lightitup
- Thank you received: 10
19 Jun 2013 04:37 #593014
by lightitup
81 kz 550 ltd
Replied by lightitup on topic 1980 airbox on 81
carbs have to be out and twist and turn every which way on mine and dont forget the brackets to hold it up :evil:
81 kz 550 ltd
- crh
- Banned
- Thank you received: 20
19 Jun 2013 07:19 #593018
by crh
Replied by crh on topic 1980 airbox on 81
Contact Cleaner is your friend when dealing with air boxes.
- County Fair
24 Jun 2013 01:34 #593695
by County Fair
1981 KZ550
1971 CT70
www.kzrider.com/forum/11-projects/588924-kz550-mine
Replied by County Fair on topic 1980 airbox on 81
I had an extra 1981 KZ 550 air box around here Ill look and see if it is still here.
1981 KZ550
1971 CT70
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
24 Jun 2013 10:03 #593709
by Proxy
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
Replied by Proxy on topic 1980 airbox on 81
On my 77 there are 2 straight boots and 2 angled boots the angled boots are on the outside. Note if your boots are hard or brittle stop now and get new boots or stop reading here as I can do nothing to help you. With the carbs out ... fold the boots over on themselves where they go onto the carbs. They will do it. It shortens the boots about an inch. Then place the boots onto the airbox and use the indexing knotches on the box with the cutout on the boots to see that they are positioned correctly. It is now pretty easy to put the carbs in place with the extra room. Hook up the cables now. Now unfold the boots over the carbs and voilar! Clamps and Bob's your uncle! Hope that helped.
I do not look forward to removing carbs or installing them but they are not a nightmare either. I was taught this by my father and my uncle and it is the best way by far. I'm pretty good at it too with about 5 minutes from go to end and no cursing or throwing things. Much luck with yours!
- nickleo373
24 Jun 2013 13:15 #593720
by nickleo373
1981 KZ550C LTD
Thanks proxy. I had to end up getting new boots because the ones that came with the air box on ebay were the originals that were over 30 years old. They should be coming in the mail today and ill give that a shot.
1981 KZ550C LTD
- nickleo373
27 Jun 2013 00:09 #594071
by nickleo373
1981 KZ550C LTD
Just got around to putting the new boots on. I rolled them over each other but still not enough clearance to put the carbs on. Are there any other tricks to doing this?
1981 KZ550C LTD
- roy-b-boy-b
- Thank you received: 103
27 Jun 2013 04:52 #594090
by roy-b-boy-b
Replied by roy-b-boy-b on topic 1980 airbox on 81
Push the rubber back into the air box.
27 Jun 2013 07:39 #594095
by 650ed
Be sure to loosen the 2 little brackets at the back of the airbox. It will let you move it toward the back of the bike just a little, but every little bit helps. Ed
