REJETTING
- Byron85
18 Jun 2013 14:32 #592887
by Byron85
REJETTING was created by Byron85
Does anyone know what the jet size should be for a 78 KZ650 SR D1A that has Pod Air Filters and a 4 into 1 exhaust. Not sure it was ever rejetted for these.
Any Help from you Wizards would be Greatly Appreciated!
- Hollywoodmx
- Thank you received: 16
18 Jun 2013 22:36 #592978
by Hollywoodmx
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Replied by Hollywoodmx on topic REJETTING
What's your altitude?
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- gd4now
- Denco where did you go?
- Thank you received: 444
19 Jun 2013 04:51 #593016
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic REJETTING
The D1a came stock with vm22ss carbs - I would suggest as a starting point the following
110 mains
17.5 pilot
remove and do not replace the #50 jets from on top of the pilots
Please note I said this is a starting point - you may find you need a smaller main and can keep the original 15 pilot.
110 mains
17.5 pilot
1977 KZ650 B1
- Byron85
25 Jun 2013 14:39 #593876
by Byron85
Replied by Byron85 on topic REJETTING
WELL I SIMPLY GOOGLED TULSA, OK. ALTITUDE AND CAME UP WITH THE FIGURE 219.76M
HOPE THIS IS A VALID NUMBER TO GO BY. THANKS AGAIN!
- Byron85
25 Jun 2013 14:43 #593877
by Byron85
Thanks for the the starting point Bud. Now the trick is to find someone who sells these sizes.
Is it possible to drill out your own sizes using a MICROMETER? If all else fails of course.
- slayer61
- KZR FLAG RELAY CARRIER #62
25 Jun 2013 15:26 #593881
by slayer61
Replied by slayer61 on topic REJETTING
I've had great luck with
www.jetsrus.com
They've had everything I had been looking for. Good luck
- bluej58
- Thank you received: 511
25 Jun 2013 20:15 - 25 Jun 2013 20:35 #593927
by bluej58
78 KZ1000 A2A
Replied by bluej58 on topic REJETTING
You can get the mains from Z1E for 1.25 each
If you got the two next sizes up it would only cost you ten bucks plus shipping.
JD
JD
78 KZ1000 A2A
Last edit: 25 Jun 2013 20:35 by bluej58.
- Flyboy
27 Jun 2013 01:59 #594086
by Flyboy
There is something otherworldy about experiencing the sound of an air cooled inline four redlined while heeled over at 35 degrees from horizontal, with the slipping rear tire violently trying to shake you from your perch atop the slewing beast..
Replied by Flyboy on topic REJETTING
Get hold of Jeff at Z1, very knowledgeable and helpful crowd there, with pods and a 4-1 you would want a Dynojet stage 3 kit, should put you right on the money, if not bloody close.
