KZ400A Way too much fuel?
- Pontiacdude210
17 Jun 2013 20:36 #592776
by Pontiacdude210
-1980 KZ550C Viper Red, Black Fenders
KZ400A Way too much fuel? was created by Pontiacdude210
I have a 77 kz400a twin. I got it torn apart and I've rebuilt the points, had the head repaired, checked the cylinders for scoring, fixed some bad wiring connections, replaced the spark plugs and fuel lines, and recently cleaned the petcock valve and the tank. I also cleaned the carbs and made sure they were sealed. I got it with one fuel line hooked up. Tank to carb pickup and that was all. When I accelerate the motor, it reaches about 4k revs then starts spitting black smoke and unburnt fuel. At low revs, it runs very rich. It will not exceed 4k revs. Several days ago while checking the ignition, I accidentally left the fuel on OFF when I started the bike. As it ran out of fuel, I could rev it much higher and it ran much better. I assume this is a carb issue, and I admit I have little knowledge on the diaphragm system in the kz400 twin carbs. It doesnt appear damaged and all the holes are clear, that's all I know for sure. Any pointers are appreciated, and the manual at kz400.com wasn't a ton of help in the troubleshooting dept. Thanks guys.
- Thank you received: 2829
17 Jun 2013 22:17 #592798
by 650ed
Replied by 650ed on topic KZ400A Way too much fuel?
A couple things to check - make sure the chokes are functioning properly and turning off all the way; perform a clear tube test to ensure the fuel in the carbs is at the correct level. Ed
- Pontiacdude210
17 Jun 2013 23:20 #592806
by Pontiacdude210
Replied by Pontiacdude210 on topic KZ400A Way too much fuel?
Thanks. I checked the chokes, they are turning off all the way. Would the wrong fuel level in the carbs mean the floats were poorly adjusted or defective? A friend just told me that could be the problem.
17 Jun 2013 23:32 #592807
by 650ed
It's unlikely that a float would be defective, although I suppose anything's possible. If the fuel level is too high or too low it most likely is the result of someone bending (on purpose or by accident) the tang upon which the float valve needle rests. Of course, another possibility if the fuel level is too high is that the float valve is not sealing properly and is allowing excess fuel to enter the carb. This case is often accompanied by fuel dripping from the overflow tube. The clear tube test should show if he fuel level is correct. Ed
