77 KZ1000 LTD Running on 3 cylinders
- K1K2K3
14 Jun 2013 23:39 #592357
by K1K2K3
77 KZ1000 LTD Running on 3 cylinders was created by K1K2K3
Hi. Have an original 100% stock 77 KZ1000 LTD. Bike was built 5/77. Less than 3000 miles. Only non factory installed parts are the battery and oil. It has always run great. Now misfiring on #1.Pipe stays cold after 2, 3 and 4 red hot. No change Hot or cold start. Compression 151 in #1. 150 #2. 151 #3 149 #4. #1 Carb looks clean. Checked and cleaned jet, pilot, installed NOS float and float valve assembly. Spark there. Swapped plugs and caps from 4. Cut off 1/4 from plug lead. New gas. Petcock spotless clean.
Any ideas?
Any ideas?
- Thank you received: 2098
14 Jun 2013 23:53 #592360
by Patton
installed NOS float -- if not already done, would perform the clear tube test to determine whether fuel level is within specs.
Replied by Patton on topic 77 KZ1000 LTD Running on 3 cylinders
Hello, K1K2K3, and WELCOME to KZr!K1K2K3 wrote: Hi. Have an original 100% stock 77 KZ1000 LTD. Bike was built 5/77. Less than 3000 miles. Only non factory installed parts are the battery and oil. It has always run great. Now misfiring on #1.Pipe stays cold after 2, 3 and 4 red hot. No change Hot or cold start. Compression 151 in #1. 150 #2. 151 #3 149 #4. #1 Carb looks clean. Checked and cleaned jet, pilot, installed NOS float and float valve assembly. Spark there. Swapped plugs and caps from 4. Cut off 1/4 from plug lead. New gas. Petcock spotless clean.
Any ideas?
- Haybus
- Big Al
- Thank you received: 42
15 Jun 2013 03:38 #592383
by Haybus
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
Replied by Haybus on topic 77 KZ1000 LTD Running on 3 cylinders
Have you pulled the plug to see if it's wet? Pulled the #1 carb bowl or drain screw to see if it's getting fuel? Could be a sticky or blocked needle valve trickling fuel into the bowl.
Alan
Alan
2005 FJR
2009 Hayabusa
