- Thank you received: 5
Mikuni BS34s won't idel down
- nivlac
13 Jun 2013 22:16 #592180
by nivlac
1983 kz1100
1979 cb650
Mikuni BS34s won't idel down was created by nivlac
I just cleaned up a set of Mikuni BS 34s and installed them on my KZ1100. They are identical to my originals but in better condition. I can't seem to get them to return to idle w/o pulling down the main linkage control by hand. It almost seems like the return spring isn't strong enough to bring it down to it's idle position. They seem to be operating perfectly aside from this issue. I'm getting ready to reinstall my air box but wanted my carbs in tiptop shape before I changed over. Any ideas?
1983 kz1100
1979 cb650
- P21
- Thank you received: 34
13 Jun 2013 22:20 #592184
by P21
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic Mikuni BS34s won't idel down
running with out rear boots on?
- Motor Head
- Thank you received: 391
13 Jun 2013 22:26 #592188
by Motor Head
Replied by Motor Head on topic Mikuni BS34s won't idel down
Also be sure of the throttle cable slack. Make sure all vacuum fitting are hooked up or plugged off.
- nivlac
13 Jun 2013 22:26 - 13 Jun 2013 22:28 #592189
by nivlac
1983 kz1100
1979 cb650
Replied by nivlac on topic Mikuni BS34s won't idel down
Currently w/o.Waiting for boot delivery trying to get the new carbs to come around prior to installing the boots and box. The current older carbs had pods on them. Currently haven't installed the pods on the rebuilt units.
1983 kz1100
1979 cb650
Last edit: 13 Jun 2013 22:28 by nivlac.
- P21
13 Jun 2013 22:31 #592193
by P21
after air box is in your going to need a carb sync
- nivlac
13 Jun 2013 22:39 #592196
by nivlac
1983 kz1100
1979 cb650
Yes it seems like the cable is slack after I pull the main cable linkage down to idle. Vacuum fittings are hooked up or plugged just as the old ones.
1983 kz1100
1979 cb650
- nivlac
13 Jun 2013 22:48 #592200
by nivlac
1983 kz1100
1979 cb650
P21 wrote: after air box is in your going to need a carb sync[/quote
Why is that? I thought syncing only made the carbs run in unison.
1983 kz1100
1979 cb650
