Strange Choke behaviour! KZ550
- accubond
11 Jun 2013 06:19 #591720
by accubond
Strange Choke behaviour! KZ550 was created by accubond
Hi,
i glued the choke flaps ,in fear of running them trough the engine, with epoxy shut. I installed Louds fast idle mod.
I can start the engine on full choke but when i lower the choke lever a bit and the fast idle cam is coming into play the engine revs very high.
Any solution for that?
I cant belive that the choke design is soo poor. Thats why i ask again. Did somebody put other carbs than TK22 on his KZ?
Thanks
Regards David
Thanks
Regards David
- boatdrinks
- Thank you received: 54
11 Jun 2013 09:07 #591731
by boatdrinks
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
Replied by boatdrinks on topic Strange Choke behaviour! KZ550
I wonder if a set of Mikuni VM22SS would work? Air box probably would have to be replaced with a KZ650 air box or go with pods but does anyone with a 550 think they would work?
Charles
Madison, AL
- boatdrinks
11 Jun 2013 09:08 #591733
by boatdrinks
Charles
Madison, AL
PS: I have an incomplete set of VM22 that I could get some measurements for you if you like.
Charles
Madison, AL
- Motor Head
- Thank you received: 391
11 Jun 2013 10:06 #591744
by Motor Head
Replied by Motor Head on topic Strange Choke behaviour! KZ550
Sounds like Fast Idle Screw is set for to high an Idle. Try backing it down some.
