- Thank you received: 1
kz650 hesitates at 1/2-full throttle
- faceplateman
These are the things that i have done
cleaned the carbs
cleaned and re-gapped the points
adjusted the timing with a timing gun
replaced the crush washers on the exhaust headers
any help would be greatly appreciated
1979 kz650 b3
- Motor Head
- Thank you received: 391
Before making jetting changes there is a few things, one make sure the ignition is correct full spark. This means check the voltage at the coils, make sure it is near battery voltage. Second, the Wet Fuel Level in the Carbs needs to be checked, not just the dry float height.
Someone will post what they are running on their 650.
- baldy110
- Thank you received: 512
Mains 105
Pilots 17.5
Needle clip middle slot
If you have the VM carbs with pods and a 4 into 1 pipe
Mains 112.5
Pilots 17.5
- 650mod
- Thank you received: 48
baldy110 wrote: What year of 650, that is going to tell which carbs you have, CV or VM. Does it have a 4 into 1 pipe? If you have the VM24 carbs and the only mod is pods this jetting should get you in the ball park.
Mains 105
Pilots 17.5
Mains 112.5
Pilots 17.5
+1 with Baldy- I'm running almost the exact setup. Mine is just running a Dynojet stage three kit in it, but needle on the same slot. Pulls HARD when you're in the top end.
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
- faceplateman
1979 kz650 b3
- Mellvis
- faceplateman
1979 kz650 b3
- ezrider714
- Thank you received: 38
One thing I didn't see that you checked was the condition of the Pod filters, make sure they are clean,if paper the best you can do is compressed air from the inside out. If they are K&N's you can use there cleaning fluid, but I've never had trouble using kerosene (off-road diesel) then oil them up with the filter oil.
The float level vs wet fuel level is way over rated, They don't just pull those float adjustment numbers out of their asses, "X" amount of float measurement will give "Y" amount of fuel in the bowl. These aren't just determined by a crap shoot. I'm sure some people have found a big difference, but just as many, such as myself have never found a big variation. One of the least useful tools I've ever bought for my bike,(in 35 yrs). Just my 2 cents
The real solution is to lose the pods unless you are going racing
Ebay can fix you up without hurting the wallet too much
About to embark on this journey on my son's 78 SR
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere)
