- Thank you received: 3
Pod filter more restrictive than stock airbox?
- cobura
- forever 2 wheels
When I ran through the gears, the bike had very little power in the higher RPMs. I took the pods off and ran it with no filter at all, ran great. This would suggest that it was running rich with the pod filters attached, correct? If that is the case, what kind of pod filters are these? I thought pod filters were supposed to increase airflow.
1979 KZ650B3
- boatdrinks
- Thank you received: 54
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
- Thank you received: 2829
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- cobura
- forever 2 wheels
boatdrinks wrote: We're you running the air box before or some other pods?
I was running the stock airbox before. Im really trying to avoid going back to the stock airbox, it just sucks so bad trying to take it on and off.
650ed wrote: Check to make sure your pods are not blocking the little orifices located near the edge of the carb throats. Some pods restrict air flow through them. Ed
Thanks! I totally forgot about that issue, I will check that out tonight.
loudhvx wrote: just to be sure, you did not oil the pods, correct? Emgos are to be run dry.
No oil on the emgos. They are indeed dry.
Does anyone know a good set of velocity stacks that would fit these carbs? I saw the ones for sale at Z1enterprises, but looking for something a bit nicer, with a screen. Bike is a '79 KZ650B, accelerator pump type.
1979 KZ650B3
- cobura
- forever 2 wheels
1979 KZ650B3
- Jrbrownie00
- Thank you received: 9
82' kz750 ltd.
