Just can't figure out these BS34's
- BLACKBEARD
09 Jun 2013 13:47 #591453
by BLACKBEARD
83 Gpz 750 named Rusty.
Just can't figure out these BS34's was created by BLACKBEARD
I'm sure there is something I'm missing. I cleaned the carbs(multiple times), rejetted the carbs #40 pilots,#122.5 mains with air pods, all vacuum lines squared away, but I just can't figure what I'm missing. I am missing one screw from my bowl. Could this create an air leak that I'm not aware of. With no motor work done,meaning all stock. Is there other options for different carbs to run?
- P21
- Thank you received: 34
09 Jun 2013 14:06 #591458
by P21
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic Just can't figure out these BS34's
i have air box still no pods
stock set-up works great is
1-slow jet 37.5
2-main jet 127.5
1-slow jet 37.5
2-main jet 127.5
- P21
09 Jun 2013 14:07 #591459
by P21
bench sync will get you going but true sync is needed and makes one hell of a differance :evil:
- baldy110
- Thank you received: 512
09 Jun 2013 17:40 #591473
by baldy110
Replied by baldy110 on topic Just can't figure out these BS34's
What exactly is the problem? And no the missing bowl screw will not give you a vacume leak.
- kimsmith4807
- Thank you received: 4
09 Jun 2013 21:32 - 09 Jun 2013 21:40 #591495
by kimsmith4807
1981 KZ1000-K1 LTD
Replied by kimsmith4807 on topic Just can't figure out these BS34's
This is for an '83 Gpz 750 right? Running pods on a cv type carb like your BS34's, albeit not impossible, will be a challenge. Your factory main would have been a #110 and the pilot jet a #37.5. Is this correct? So, you've upped both of them. Like baldy said, what is the issue?
1981 KZ1000-K1 LTD
Last edit: 09 Jun 2013 21:40 by kimsmith4807.
- BLACKBEARD
09 Jun 2013 23:45 #591533
by BLACKBEARD
Replied by BLACKBEARD on topic Just can't figure out these BS34's
The bike starts and runs with the choke on. As soon as I hit the throttle or turn the choke off it dies. It was doing this before, so I soaked them in pine sol. When I put them back on it got a little better,so i soaked them again... Now this.
- baldy110
10 Jun 2013 13:28 #591593
by baldy110
That info helps a lot, your carbs are still dirty. Those symptoms are classic for dirty carbs. Take them back off and throughly clean them, pay particular attention the small passegeways in the carb body. Make sure all those passegeways are clear, simply soaking them will not work. After soaking them I always followup with carb cleaner and make sure the cleaner goes through all the passegeways. I then follow up with compressed air. Anytime an engine only runs with choke the carbs are usually clogged up.
- peter1958
- Banned
- Thank you received: 198
10 Jun 2013 13:33 #591595
by peter1958
Replied by peter1958 on topic Just can't figure out these BS34's
This might help you.
www.mtsac.edu/~cliff/storage/gs/Mikuni_B...Rebuild_Tutorial.pdf
- mtkawboy
- Thank you received: 16
11 Jun 2013 18:06 #591782
by mtkawboy
Replied by mtkawboy on topic Just can't figure out these BS34's
There is a hidden passage way between the hole where the main jet goes over to to where the idle mixture screw is. It caused me to take my carbs off 4 times before I sawed an old carb in half & found it. This will cause the bike to run reved up it have a dead cyl on the carb with that plugged up idling. You can fish a piece of guitar string thru there to clean it out. I have a whole assortment of different size guitar strings from .012 to .017 for that purpose I bought for under $10. Do you have the rubber or metal caps on the pilot jet hole installed ? I hope some of this helps.
- Thank you received: 2098
- BLACKBEARD
11 Jun 2013 23:29 #591857
by BLACKBEARD
I see what yur saying, I will definatly attack it with the small strings. Especially seein how you disected one.
