- Thank you received: 116
78 kz1000 high idle
- floivanus
07 Jun 2013 23:43 #591289
by floivanus
Past; 78 kz1000, 83 kz550
Andrew
78 kz1000 high idle was created by floivanus
Got the carbs back on my 78 cables adjusted, new boots and carb holders, but i can only getthe idle down to 2/2500 rpm
If i twist forward on the throttle i can drop her to the grand range until i let off, i assume pop the carb tops off and drop all four slides equallywould be a good idea?
Andrew
- Thank you received: 2829
07 Jun 2013 23:56 #591291
by 650ed
Replied by 650ed on topic 78 kz1000 high idle
Have you tried turning the throttle stop knob counter-clockwise? Ed
- floivanus
08 Jun 2013 00:09 #591292
by floivanus
Andrew
Replied by floivanus on topic 78 kz1000 high idle
Hasnt been touching anything for ages ed, i've got a quarter inch gap between it and anything else
Andrew
08 Jun 2013 00:47 #591294
by 650ed
That makes me suspect that it was not centered when the carbs were bench synch'ed. You may want to crank it in a fair amount and then drop the slides down an equal amount. If you do that and then synch the carbs you should end up being able to use the throttle stop in the future to adjust the idle. ed
- floivanus
08 Jun 2013 01:06 #591295
by floivanus
Andrew
Thats my thought so far, i didnt synch or bench synch them myself, just cleaned and replaced them.
Will try in the morning, this thing doesnt have a baffle in it and my neighbors already dislike me as it is
Andrew
- floivanus
08 Jun 2013 11:43 #591319
by floivanus
Andrew
Took off the caps adjusters were way high, turned them all in a turn and a half, idles too low. Idle stop screw is to short, its an allen bolt, grabbed a different one and now it idles at 1500, pops quite a bit at idle but that did the trick
Andrew
