- Thank you received: 50
Hard starting after carb overhaul
- guitargeek
07 Jun 2013 21:32 #591271
by guitargeek
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Hard starting after carb overhaul was created by guitargeek
Mikuni BS34s on KZ750-4, 117.5 mains, 35 pilots, freshly synchronized. Very snappy response, but demands ether when cold... if I recall, I set the screws 1.5 turns out.
Ideas?
Ideas?
- Motor Head
- Thank you received: 391
07 Jun 2013 21:38 #591272
by Motor Head
Replied by Motor Head on topic Hard starting after carb overhaul
2 turns out would be a better starting point. You may need to adjust each individually from there.
When you were cleaning the carbs, did you pay close attention to both the pilot, and the starter circuits?
Any vacuum leaks?
In order for the "Choke" to function, as it is actually an enricher, don't touch the throttle when cold. It needs that high vacuum at the engine side of the carb to pull fuel through the enricher.
Any vacuum leaks?
The following user(s) said Thank You: guitargeek
- guitargeek
07 Jun 2013 21:47 #591276
by guitargeek
Replied by guitargeek on topic Hard starting after carb overhaul
Carbs were separated, soda blasted and ultrasonically cleaned, all passages blown out.
I'll try turning the air screws out another half turn...
- guitargeek
12 Jun 2013 15:54 #591959
by guitargeek
BINGO!Motor Head wrote: 2 turns out would be a better starting point.
