Carbs geting gas, but not to spark
- lroberts
Just put the bike back together but I can not get her started. The carbs are getting gas and on the kickstand side, the card vent line is leaking gas when the gas is on.
Any ideas why that would be?
Also I checked my plugs by taking each one out and placing it on the block to see if they spark and each one does. But I notice there is no smell of gas. They are not even wet. Any ideas what is stopping gas from reaching the plugs?
- bountyhunter
- Thank you received: 337
That problem is so common it should have it's own sticky. It means the carb needle/seats have a problem sealing and/or the floats need to be adjusted to get the fuel levels in the bowl right.lroberts wrote: 1979 KZ750 Twin
If not already done:
rinse fuel tank with clean solvent or gas, clean petcock assy and install inline filters. Crud coming down will cause sealing problems.
Then drop the bowls and remove the floats/needles/seats and clean and polish them so they will seal.
use the clear tube to set fuel levels and no more problems.
- lroberts
Side not.... While I was trying this today the solenoid went bad so I am having t turn the key to on, set the switch to run, and then jumping the solenoid with a screw driver. The engine turns over great and I am getting spark on both sides but its not a great spark.
Any ideas?
- Thank you received: 2829
- lroberts
Choke not on.... Then try giving some gas
Choke on.... Then try giving some gas
I would think it would at least sputter or something. My plugs are REALLY black and even though they are sparking I am wondering if its the plugs.
Either that or......
I had to run a new wire from the points but I do get spark but it does seem weak.
- lroberts
Also how do I adjust the float to stop the gas leaking from the vent?
- bountyhunter
Flooding = flooded engine which is impossible to start.lroberts wrote: Ok so now I have new plugs, confirmed they are sparking yet still no start. I am really at a loss. Carbs have been cleaned twice, new plugs, new battery.... And I have gas leaking again front the vent. Could the no start be electrical?
You need a factory service manual. I got one on CD for $5 on ebay.
lroberts wrote: Well I have tried the following....
To start a cold KZ engine the drill is as follows:
Fully charged battery
Petcock "On" (or "Prime" if vacuum actuated)
Kill switch in "Run"
Choke On
Ignition key On
Do not touch the throttle at all.
With the above done pull in the clutch lever and hit the start button
OR
Don't pull in the clutch lever and use the kick starter (if your bike has one).
- bountyhunter
If your carb is flooding, it isn't going to start.
- lroberts
Still have gas that leaks out the kick stand side carb through the vent but that I can live with.
