- Thank you received: 23
1977 KZ1000LTD need help getting back on AIRBOX
- 74ullc
When I bought my 1977 KZ100LTD it had pods installed by the PO. I guess he threw most all the parts away when he switched over to pods because all he had was the empty airbox itself. No tubes, lid, filter, hoses, wire baskets that go inside the box, flange to hold on the tubes...all that stuff was missing.
I have managed to round up just about everything I need. I got a used airbox assembly with the guts and tubes all there, even has the crankcase vent tube!
I also ordered stock jets for the carbs (VM26SS), new air filter, and new carb holders from Z1E. My originals have leaks like everyone elses. The airbox tubes I have seem very soft so I am going to try to use them, if they crack during install then I'll order a new set of those too.
Tonight I pulled off the carbs and was doing a dry run installing the airbox just to make sure its all going to work. Well....seeing that there is nothing to support the airbox I pulled up BB and after searching finally end up on the battery box page and see I am missing the "stay, air cleaner" #15.
www.bikebandit.com/houseofmotorcycles/19...b/o/m150658#sch35425
Along with the airbox stay I think I am missing parts #18 and #20 and I know I am missing the tool tray, #21.
I do not have the silencer #15 from this page.....
www.bikebandit.com/houseofmotorcycles/19...b/o/m150658#sch37559
I knew I was missing the silencer but was hoping its ok to run the airbox without it. Is that ok?
Also does the "stay, air cleaner" support the box? I know the box cant just hang on the tubes from the carbs!
I'll post some pics tomorrow of what I have to work with....just wanted to get a post up and running to see if anyone can help me out with what all I am going to need to get the airbox back on the bike. I would also like to get all the battery box parts rounded up if possible.
I'll call BB tomorrow and try to find out if they by chance actually have the airbox stay and battery box parts in stock. If not looks like I'll be fabbing at least the airbox stay. Looks to be just a simple piece anyways. If anyone can get me some measurments on the airbox stay that would be a big help.
I'm looking forward to finally doing some wrenching on the old girl again!
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
- Thank you received: 2829
- 74ullc
Of course BB didn't really have one, neither did the local Kaw dealer.
Still have to round up the other parts for the battery box I'm missing but I don't need those right away. I got the carbs all apart now....thinking really hard about soda blasting them. I've done it with other carbs and they come out like bran new. But its such a pain to empty the glass out of the blast cabinet and make sure that every little spec of glass is out of it. Sure don't want a glass bead getting lodged in a passageway.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
- 74ullc
They turned out looking good. I really like using the soda because it is very gentle. It just cleans surfaces, it will not eat into the metal. It even left the factory yellow paint on the choke bracket screws intact. I didn't polish the bowls or top covers, just left them as they came out of the cabinet. Trying to get a factory look to them.
The bike is all back together and now has fresh tags and inspection. I'll get some pics of the carbs on the bike up soon. Original airbox in place made it interesting to get the carbs back on.
Running good except has a little bog just off idle (leaving stoplight). I went with one size up on mains and pilot based on advice from Z1E. I'm at sea level and would rather be a touch on the rich side than lean. If I understand correctly a bog just off idle would be a rich condition, but I had to go two full turns out on the fuel screws to get it highest idle. Book says 1 turn +-1/4, so being 2 full turns I would think the pilots are too small? The extra 3/4 turn out on the fuel screw indicating a compensation for the lean pilots? But a bog off idle is usually a rich condition? So I have to get that figured out.
I have just done a mech sync on the carbs so that could be the problem too. I need to get a set of gauges to do a vacuum synch.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
- 74ullc
It's like a new bike, runs great! Sounds better, looks better, runs better....just better. I'm still missing the silencer but I'll be looking out for one.
I still have work to do but its getting closer to all stock.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
- TomW
- Keep the blue side up.
- Thank you received: 52
A lot of good work can be done with a hacksaw and a file. My hat is off to you, sir. When I take the fairing and bags off my '78 LTD they'll look like twins.74ullc wrote: $37 and waiting for it to be shipped?....nah....30 minutes and a little shot of paint....
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
- upncummr
- Thank you received: 16
Gary
- 74ullc
For anyone putting their carbs on, I recommend leaving that plate off during install. It lets you push the airbox back and down further. Then after the carbs are in place lift the airbox and slide the plate into place under it and bolt it down.
The carbs did come out nice....they look kinda blue in the pics. I don't know why that is. They look like freshly cast bright aluminum in person. I don't think the soda is coloring them???
I've already had a few people ask me where I found new set of carbs from.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
- kaw-a-holic
- Thank you received: 249
74ullc wrote: Went ahead and soda blasted the carbs. Just used the little table top HF cabinet instead of emptying the full size econoline. Using the little cabinet reminds me just how much better the real cabinet is!
Nice job! now I want to do that to mine damn it! The list is supposed get shorter.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
