- Thank you received: 2
TUNING (KZ400 - 2-1 VM34)
- treitz
Now that I have the right size carb, the Mikuni VM34, I am getting REALLY close. But I could still use a little input.
3 areas of adjustment on this carb are the pilot jet, the needle, and the main jet. I started out really rich so I kept going down on everything until it was lean. Then wen't one up. Here's where things get weird...
Right now, at low-mid RPM's it is acting lean at time. Not all the time, but most of the time. Leading me towards the pilot jet and/or the needle. More than likely the needle because it's not lean right off of idle, but slightly above.
The strange thing is that my plugs are still pretty black. But I can't really feel anywhere in the power band where it is rich.
I guess if I narrow it down to which jets are lean (like the pilot and/or needle) then by the process of elimination I could assume that the main is rich?
Thoughts?
1979 KZ400 - 2-1 Manifold - Mikuni VM34
- loudhvx
- Thank you received: 1616
The reason it is like this, is because you will do all of your light cruising at the small throttle opening, and there will be a benefit in fuel economy. It won't affect power, since you won't be in that region while riding hard. The problem is, there is a very tricky balance you have to achieve, and your setup is just a little bit too lean in that region. The solution is to raise the needle slightly (a full step will usually be too far, but you can try that first), and compensate down on the main jet and pilot jet and mixture screw.
I'm not familiar with how you raise the needle on the VM34, but if you put a shim under the needle clip to raise it, make sure the needle is not mechanically bound tight. That can wear the orifice the needle goes into.
Using a wideband O2 sensor makes it easy. It will take more time if you are just test riding and looking at plugs etc. Also pay attention to the color of the tailpipe.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- treitz
loudhvx wrote: That is not an uncommon problem. What I find is, there is a short section where the needle is not tapered (or in the 550's, tapered too little). When you are just off idle, you will be on that section of the needle. Since it is not adding fuel as you just start to open the throttle, it goes drastically lean for that tiny bit. However, your idle and any position beyond that can still be very rich.
The needle in the VM is actually adjustable. It has a clip that you can move up and down. It is currently on the middle of 5 settings.
You're thinking that I should go richer (up), like one clip, on the needle, but leaner on both the main and pilot?
- treitz
- loudhvx
But realize, jetting is not really easy to diagnose over the internet. I can only make guesses to what you need.
A wideband O2 sensor is usually not a rentable tool. You have to weld a bung into the exhaust for the o2 sensor, and hook it up to a micro-controller with a gauge or logging system.
kzrider.com/forum/3-carburetor/307483-in...-sensor?limitstart=0
The second page of that link shows some AFR results for steady throttle positions. Notice it starts relatively rich at idle, then goes very lean, briefly, as the throttle position is off idle (cruising), then goes back to slightly rich for all higher throttle positions.
CV carbs are a little trickier because the slide position is a big unknown for any given throttle position.
Another side note, in case you didn't know... when you open the throttle, the mixture goes rich until the engine catches up to the throttle position, and as you close the throttle, the mixture goes lean until the engine slows down to the throttle position. That's why if you ride the bike like a bat out of hell, the small lean-hesitation disappears. It's only when you do some slow cruising that you notice the hesitation.
1981 KZ550 D1 gpz.
Other links.
- treitz
Also, the VM34 is not a CV carb. It is a round slide carb.
I understand what you're saying about how you ride it. When riding like a "bat out of hell" I hardly notice any lean hesitation at all. When cruising at a few thousand RPM, and then letting off the throttle is when I notice it. Or when revving it slowing (from a stop behind a slow ass car) it feels lean if I shift at low RPM, but not at higher RPM's.
- loudhvx
treitz wrote: Thanks for all of the great information. I will see if I can find a o2 sensor that will work for me.
Yeah, I was just mentioning the CV to support manual-slide combo being way easier to tune.
With a manual slide carb, throttle control is more important when the mixture is correct. When it's lean, you can usually crank them open as fast as you want. As the jetting is set richer in the lower areas, you may have to control how fast you twist the grip... which is normal (and basically what the CV does automatically).
1981 KZ550 D1 gpz.
Other links.
- loudhvx
Way cheaper now. "Buy it now" $208, I paid closer to $350, I think.
1981 KZ550 D1 gpz.
Other links.
- treitz
- treitz
Haven't had a chance to check the plugs yet. Will do that tonight.
Brand new plugs. Hoping they are black as hell like the rest of the plugs I've used in it!
Only issue I am still having is that it runs pretty lean when it's cold out. Between 40 and 60 degree's in the morning it run leans. Mid day to evening when it's 80+ it runs 10 times better.
- treitz
Still occasionally lean at low RPM's, but my plugs are still really black. Tempted to lean out the main one to see what happens.
Why the hell does it feel and act like I'm running lean, but my plugs are still black?
I am running stock Sportster mufflers which are pretty restricting. Do you think opening up my pipes would offer a improvement?
Current specs (as much for my own documentation as for you):
Carb: Single VM34
Pilot: 25
Needle: Middle clip
Main: 145
Air filter: POD
Exhaust: 2-2 sportster slip-on's w/ header wrap
