- Thank you received: 1616
1980 KZ 550A1 TK carb issues
- loudhvx
02 Jun 2013 23:40 #590588
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic 1980 KZ 550A1 TK carb issues
If you are running a car fuel filter with paper element, those can cause flow problems. You will want to switch to a metal screen type or scintered bronze/brass.
1981 KZ550 D1 gpz.
Other links.
The following user(s) said Thank You: johnf1059
- johnf1059
03 Jun 2013 00:07 #590599
by johnf1059
Replied by johnf1059 on topic 1980 KZ 550A1 TK carb issues
I am running a paper filter or was. I removed it. I will get a screen filter tomorrow thanks!!!
- johnf1059
06 Jun 2013 08:15 #591040
by johnf1059
Still have to run choke. I have 92 mains. And 32 pilots. Air screws are caped. The bike is idling erratic, sputtering at cruising speed, and accelerates pretty good. What should i do to try to correct this? Thanks!!!
- loudhvx
06 Jun 2013 13:36 #591086
by loudhvx
1981 KZ550 D1 gpz.
Other links.
Well, it's probably time to start from the beginning.
Compression check.
Valve lash check.
Ignition advancer check.
Timing check per manual.
Voltage to coils check.
Check for vacuum leaks.
Put caps on all 4 intake manifold ports.
Make sure petcock vacuum line is not cracked or leaking.
Inspect all intake manifolds for cracks etc.
Then on to the carbs.
Check the plugs to make sure all four are the same. You can't do any jetting if they are different.
Compression check.
Valve lash check.
1981 KZ550 D1 gpz.
Other links.
