- Thank you received: 1
Discolored Header pipes - running lean?
- Yorkie
01 Jun 2013 18:05 #590311
by Yorkie
'72 Z1
Discolored Header pipes - running lean? was created by Yorkie
The number 3 and 4 pipes on my new-to-me '72 Z1 are colored gold nearest the cylinder head but 1 and 2 are normal chrome ( the bike has a replacement 4 into 4 system ) so can I presume that it have been running lean at some point? I checked the air screws and they are one and a half turns out. What else could cause it to run lean?
Thanks,
Kevin
Thanks,
Kevin
'72 Z1
- kimsmith4807
- Thank you received: 4
01 Jun 2013 20:23 #590330
by kimsmith4807
1981 KZ1000-K1 LTD
Replied by kimsmith4807 on topic Discolored Header pipes - running lean?
An open header flows more causing your A/F mixture to lean out. Jetting changes in all circuits are likely.
1981 KZ1000-K1 LTD
- kawasaki mike
- kawasaki mike
03 Jun 2013 21:16 #590724
by kawasaki mike
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
Replied by kawasaki mike on topic Discolored Header pipes - running lean?
The first thing to check would be fuel level. Always do that first. Then check timing. Then check sinch. Now your ready to jet accordingle. Go by what the plugs tell you.And yes, gold pipe is lean symptom.
The following user(s) said Thank You: Yorkie
- Thank you received: 797
04 Jun 2013 10:32 #590796
by 531blackbanshee
Replied by 531blackbanshee on topic Discolored Header pipes - running lean?
are you sure the header has been on the same bike the whole time?
- Yorkie
05 Jun 2013 03:51 #590910
by Yorkie
'72 Z1
Replied by Yorkie on topic Discolored Header pipes - running lean?
when I bought the bike it had been "restored" and the never run. The pipes were new.
kevin
kevin
'72 Z1
- Thank you received: 2098
05 Jun 2013 06:49 - 05 Jun 2013 06:50 #590914
by Patton
Presumably fitted with stock air-box and stock-type paper filter, to rule out any pod-related issue.
Replied by Patton on topic Discolored Header pipes - running lean?
If not already done, could also also check for possible air leak (for whatever reason) at number 3 and 4 carb holders, which leak is often accompanied by a "racing idle" issue.Yorkie wrote: The number 3 and 4 pipes on my new-to-me '72 Z1 are colored gold nearest the cylinder head but 1 and 2 are normal chrome ( the bike has a replacement 4 into 4 system ) so can I presume that it have been running lean at some point? I checked the air screws and they are one and a half turns out. What else could cause it to run lean?
Thanks,
Kevin
Last edit: 05 Jun 2013 06:50 by Patton.
