Tuning
- gremlin497
01 Jun 2013 10:42 #590259
by gremlin497
1977 KZ 1075 (FBG), 29 Smoothbores V&H Mega
Tuning was created by gremlin497
I have 1977 kz 1000 that trying to tun with Carbtune. Have should CG/HM ready on Carbtune when tuning 29smoothbore carbs. By has stock cams with 1075 piston kit? Any help appericated.
- baldy110
- Thank you received: 512
01 Jun 2013 23:22 #590369
by baldy110
Replied by baldy110 on topic Tuning
- Old Man Rock
- Thank you received: 225
02 Jun 2013 08:21 #590403
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Tuning
Same here, not sure what the question really is.... :S
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- crh
- Banned
- Thank you received: 20
02 Jun 2013 09:13 - 02 Jun 2013 09:15 #590407
by crh
Replied by crh on topic Tuning
I remember this person. He's from Rochester NY area I can't pull the name out of my memory bank at the moment but I remember you and your wife....and of course your bike
Are you asking how many inches of Hg you should be seeing on the meter? With stock cams and everything healthy you should see at least 7" at idle.
Don't worry about what that number is. You want them all as even as possible. If for example you have 3 at 7" and one at 8", drop the 8" cylinder to 7"..... you get the idea??
If they are all over the place when you have the bike idling at 1000RPM, bump the idle to 1500RPM, get them even, then drop to 1000RPM idle and repeat. Put a fan on the engine while you're doing the synch.
The adjusters on the 29's are touchy. It's a feel sort of a deal....
Last edit: 02 Jun 2013 09:15 by crh.
- gremlin497
02 Jun 2013 11:04 #590424
by gremlin497
- kawasaki mike
- kawasaki mike
- Thank you received: 4
03 Jun 2013 21:11 #590720
by kawasaki mike
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
Replied by kawasaki mike on topic Tuning
I have the same set up and at idle I read 9.5 hg At 1500 rpm I get 11.5 to 12. Good luck
