- Thank you received: 2
Replacement fuel petcock
- DesertWizardB1
28 May 2013 14:37 #589596
by DesertWizardB1
Len
77 KZ 1000 LTD Original Owner
Replacement fuel petcock was created by DesertWizardB1
Anyone know where I can get an inexpensive fuel petcock for my 77 KZ1000 LTD? My tank is the original one with the 22mm single hole. I checked Z1 Ent. but it looks like Jeff just has Pingels now and I don't want to have to spend $90 bucks. Unfortunately I didn't see a rebuild kit there either. I don't care if it has a reserve position just a simple on/off would be fine. If I need to use an adapter it would have to be 22mm to fit the tank. Any suggestions appreciated.
Thanks,
Len
Thanks,
Len
Len
- moneypit
- Thank you received: 35
28 May 2013 17:37 #589608
by moneypit
2-76 kz900
St Paul MN
Replied by moneypit on topic Replacement fuel petcock
2-76 kz900
St Paul MN
- DesertWizardB1
28 May 2013 19:08 #589612
by DesertWizardB1
Len
Replied by DesertWizardB1 on topic Replacement fuel petcock
Thanks for taking the time to reply. I saw this kit but it doesn't include the part I need which is the plastic cone with 2 holes in it that is the actual valve. My petcock doesn't leak gas on the outside it won't shut off completely. Thanks again.
Len
Len
Len
- MFolks
- Thank you received: 540
28 May 2013 19:28 #589617
by MFolks
Replied by MFolks on topic Replacement fuel petcock
As time goes on,we're finding out how the Ethanol in the gas affects our older bike's fuel systems. It will dissolve some plastics, and attack rubber fuel system parts. It has been reported to internally swell fuel lines to the point that gas barely flows, and if your float bowl needle valves are rubber tipped, it will atack them too.
- DesertWizardB1
28 May 2013 21:29 #589635
by DesertWizardB1
Len
I agree, the vinyl fuel line I use gets hard as a rock in just 1 riding season. I'm switching to tygon tubing this year.
Len
- bluezbike
- Thank you received: 104
28 May 2013 21:41 #589636
by bluezbike
79 KZ 1000 LTD
Replied by bluezbike on topic Replacement fuel petcock
One alternative is to use fuel tubing designated for fuel injected car motors....it does seem to be pretty resistant to Ethanol in today's fuels.
79 KZ 1000 LTD
- Thank you received: 2829
28 May 2013 22:04 #589640
by 650ed
Here's what I bought (5/16"). You can buy it by the foot and it should last a very loooong time. Ed
www.gates.com/brochure.cfm?brochure=12468&location_id=541
Replied by 650ed on topic Replacement fuel petcock
DesertWizardB1 wrote: I agree, the vinyl fuel line I use gets hard as a rock in just 1 riding season. I'm switching to tygon tubing this year.
The following user(s) said Thank You: bluezbike
- Thank you received: 1656
29 May 2013 11:43 - 29 May 2013 11:44 #589722
by martin_csr
Replied by martin_csr on topic Replacement fuel petcock
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationTry looking around the Drag Specialties site - search for Petcock - some are available in 3/8" NPT or 22mm.
Searching for Drag Specialties petcock on ebbaayy:
Last edit: 29 May 2013 11:44 by martin_csr.
