lost o-ring?
- ggenovez
27 May 2013 22:31 #589505
by ggenovez
KZ-1100 A1
lost o-ring? was created by ggenovez
Hi all,
I think I'm asking about a null issue but I figured better safe than sorry.
I was teaching my son about carburetors and cleaning out my mikuni on my kz-1100.
I rinsed the off and then told him to air dry them with the compressor.
While doing that the flat o-ring that sits on the carb body blow away, never to be seen again. I figured I better order a replacement. Kawasaki.com does not she that the part is there??? odd?
This is the o-ring that sits after the pilot jet. looking closer, the o-ring doesn't really cover anything and when you but the bowl back on it covers the area with the o-ring???
Was that part removed post production?
Thanks
G
Thanks
G
KZ-1100 A1
- Motor Head
- Thank you received: 391
28 May 2013 09:54 - 28 May 2013 09:54 #589565
by Motor Head
Replied by Motor Head on topic lost o-ring?
That o-ring is not sold that I know of. I have used a regular o-ring in its place with out issue.
You can buy an o-ring kit from several stores that will have many sizes, or just a single o-ring size. Ace Hardware has drawers with these. Harbor Freight has kits, as well as most Auto Parts Stores.
Last edit: 28 May 2013 09:54 by Motor Head.
The following user(s) said Thank You: ggenovez
- ggenovez
28 May 2013 09:56 #589566
by ggenovez
KZ-1100 A1
Replied by ggenovez on topic lost o-ring?
Thanks Motor head.
I guess my question is, since it does not really seal anything and it's already covered by the float gasket, is it even needed?
KZ-1100 A1
- Motor Head
28 May 2013 10:04 #589569
by Motor Head
Well there is a metal plug there in the carb body. So it is there to seal the plug off, along with the bowl gasket. Are both really needed? Well they/ Kawasaki thought so. o-rings are cheap.
- ggenovez
28 May 2013 10:06 #589570
by ggenovez
KZ-1100 A1
Very true,
But they also removed it from the diagram
Like you said they're cheap, I'll just make a special trip for them.
Thanks
G
Thanks
G
KZ-1100 A1
