81 kz 500 ltd hard to start cold
- wtrtdog
26 May 2013 21:30 #589332
by wtrtdog
81 kz 500 ltd hard to start cold was created by wtrtdog
hello i just bought a 81 kz 550 and am a new rider.the problem i have is trying to get bike running when cold.it will start right up when choked.the rpm go upto around 4000 then settle down.if i take the choke off it will stall right away also when i give it gas it will stall.after a while it is like hitting a switch it will run fine and idle fine without the choke.but if it sits an hour it is hard to start again.once it is warm it runs great.not sure what to try i have replaced the plugs and ran some seafoam thru in the gas.any advice would be much help.
- Spectre1982
- Thank you received: 9
27 May 2013 02:15 #589366
by Spectre1982
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
Replied by Spectre1982 on topic 81 kz 500 ltd hard to start cold
Probably needs a thorough carb cleaning and tune. Not too hard after some research.
1978 Kawasaki KZ200
The following user(s) said Thank You: wtrtdog
- P21
- Thank you received: 34
27 May 2013 11:12 #589390
by P21
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic 81 kz 500 ltd hard to start cold
check float level while in there
