KZ650 78 Starts Great Warm but Hardly Starts Cold?
- RTZ
23 May 2013 00:09 #588837
by RTZ
KZ650 78 Starts Great Warm but Hardly Starts Cold? was created by RTZ
Hello All,
My KZ650 takes forever to start when cold, if at all. After trying for a long time then letting it sit for a bit it will start. Once the bike is started it runs and starts great. If I let it sit for longer than one hour it is impossible to start again. I just cleaned and replaced the jets in the carbs to rectify the problem but it did not help, any suggestions?
Thank you!
Thank you!
- Thank you received: 2098
23 May 2013 00:21 - 23 May 2013 00:22 #588842
by Patton
Replied by Patton on topic KZ650 78 Starts Great Warm but Hardly Starts Cold?
Entire pilot circuit should be "as new" clean.
Entire enrichener (choke) circuit should be "as new" clean.
When starting the engine on choke, don't touch the throttle grip.
Last edit: 23 May 2013 00:22 by Patton.
