KZ 1000 '79 jetting
- woodsy
22 May 2013 17:00 #588781
by woodsy
KZ 1000 B3 ltd - Imported from USA in 1994 - Live in Cornwall UK
KZ 1000 '79 jetting was created by woodsy
I have just broken the pull rod that activates the accelerator pump, i tried to get a new one but as my bike is a US import (I live in UK) no one has one and the part is obsolete, i have been told that i can do away with the accelerator pump as none of the UK versions had them and upjet the main jets to compensate. I have cable tied the accelerator pump arm out of the way
I am using the stock air box and the jets in there at the moment are 110s
What size should i go up to, to compensate for no accelerator pump, 115s have been suggested ??
any help would be gratefully received
- Nebr_Rex
- Thank you received: 300
22 May 2013 23:26 #588827
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic KZ 1000 '79 jetting
110s are stock on shaft drive ,all the other were smaller.
The main jet size shouldn't be affected.
It would be your pilot and needle.
I would see how it runs as is and if need be raise the needle and/or larger pilot.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- 771000LTD
23 May 2013 09:25 #588868
by 771000LTD
Replied by 771000LTD on topic KZ 1000 '79 jetting
I saw one on ebay today.look any thing to with 1979 kz1000 shaft.pretty sure that's where I saw it
good luck
i
good luck
i
- 771000LTD
23 May 2013 09:27 #588869
by 771000LTD
