New Air Filters fitted now it overheats
  • ror24
  • ror24's Avatar Topic Author
03 Jul 2006 05:33
#58870
Help.
Have fitted new air filters on my KZ750E1 and starts fine. Within 5 minutes of running from cold the block is really hot and much hotter than prior to changing over the filters.
With the new intake is the engine running too lean and do I need to adjust and sync the carbs?
Hope someone can help.
Thanks and regards
  • pidaster
  • pidaster's Avatar
Re: New Air Filters fitted now it overheats
03 Jul 2006 05:39
#58871
If you put hi flow filters on then you will most likely have to re-jet for proper mixture.
  • donthekawguy
  • donthekawguy's Avatar
03 Jul 2006 06:01
#58872
You have to rejet. A good baseline I think is up two sizes for each mod.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
